The big one Eversolo vs Eversolo 'Master'!
Purité Audio
Industry Insider
Barrowmaster
London
I know its the question that keeps you awake at night, is the Eversolo 'Master' edition with its fancy dual femto clocks and swish 1642 op-amp really better than the lowly standard version.
Once you strip away the gold bling whats underneath?
There can be only one.
Can you handle the TRUTH?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
One cock-up already, 1612 is in the Master edition!
Looking through the specs I can’t see any other differences, RCA and XLR outputs are the same 2.6 and 5.2 respectively, level matching should be easy.
My plan is to use Roon to switch between Eversolo streamers , connecting the same channel to one of my drive speakers.
They have both digital and analogue inputs so I can compare both digital and analogue outputs of the Eversolo’s.
The only issue is that the active speakers here all have. their own internal processing but that will be the same for both units.
I will check the output voltages of both, what haven’t I considered?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The ‘Master’ has entered the building !
There is at least one more change to the standard, the label is orange!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
And upside down!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Gold, you’re indestructible always believe in…
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It lives,
It does look nice in orange, whether it is £441 nicer?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
You will be pleased that ‘knob feel’ is unaltered.
Keoth
fpitas
Northern Virginia, USA
I'm going to go out on a limb and say there *may* be a slight measurable improvement. But completely inaudible. Blaming jitter and op amps is the modern equivalent of blaming the dog.
Astoneroad
a Cave in the desert
Doggie jitter is much more adorable... sometimes audible... sometimes with a side of slobber... much like many claims of audio bipeds...
<iframe src="https://giphy.com/embed/YBmaAyZKVb9fa0klba" width="480" height="480" frameBorder="0" class="giphy-embed" allowFullScreen></iframe><p><a href="
">via GIPHY</a></p>
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The plan is to hook both units up to some speakers using their analogue outputs , ensure the levels are the same, specs for both machines are identical RCA and XLR , then switch between unsighted.
I don’t have two pairs of speakers but if I push them close together , connect the same channel to the speakers I think I should be comparing like for like?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Eversolo DMP A-6 ‘midi system’,
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Lana ‘all you kids with your vintage music’,
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I am wishing that I still had my Benchmark HPA4 here
usefully it has two sets of analogue inputs on XLR
I could connect the analogue outputs of both Eversolo DMPs ‘Master’ and standard.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I have booked the services of my wife ( who heard the difference from the kitchen) .
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I think to make this a really valid comparison I need a preamp and this looks ideal
If I get the ‘extender for it as well that gives me more than enough inputs.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Or wait for the Eversolo DMP A-8 which has two analogue ‘ins’ but one on XLR and one on RCA.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Output from the DMP A-8 is slightly less from both RCA and XLR compared to the A-6
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
I have been comparing this afternoon and frankly I can’t hear any difference whatsoever between the two Eversolo DMP A-6 units standard and ‘master’ , but I realise that I am predisposed to not hear a difference, the Eversolo DMP A-8 should arrive soon, hopefully it will be Roon Ready by the time it arrives.
It has two analogue ins on RCA and XLR which will allow me to not only compare the analogue outputs of the Eversolo’s but the Wiim Pro Plus as well.
Which will hopefully also make a slightly more interesting comparison.
