Newman
- Joined
- Jan 6, 2017
- Messages
- 3,537
- Likes
- 4,387
Trying to untangle the OP's pretzel here.
The "dashed orange line" in post #28 is from an old (maybe 15+ years) bit of research where Harman were comparing several early auto-EQ systems to one another and to no-EQ. These auto-EQ systems all measured and equalized the ungated in-room frequency responses. Some of them actually made things subjectively worse than no EQ at all. The best of the bad bunch was the one that looked like the dashed orange line. That's why it is called "the preferred target" -- preferred to whatever target the others were working to, out of that bunch of products.
So Harman were saying, if you were going to equalize loudspeakers based only on in-room, at-the-listening-seat measurements that are ungated, then that dashed orange line is your best-bet target. Best of the set of targets they compared.
Then Olive makes the observation that, if you take a flat-anechoic-response speaker like the Revel F208, and measure it ungated at the listening seat, it already matches the orange dashed line, with no EQ needed, except in the bass region. Well, near enough to make the following point, namely, that except in the bass, using the orange dashed line as an averaged-in-room ungated EQ target is really equivalent to adjusting the speaker's direct-arriving sound to a more-or-less flat frequency response.
So, nowadays, with better in-home analytic software that can take gated measurements outside of the bass frequencies, we can be more direct. Instead of using the dashed orange line as a target as a proxy for roughly getting the gated (direct-arriving sound) response flat, we can more precisely get the direct-arriving response truly flat by measuring it directly.
As for the green curve, please realize that it is being measured inside the ear. Olive is trying to explain that when you take a speaker like the F208 with its flat anechoic (direct-sound) frequency response, and measure the response inside the ear, you will get that green line with the big bump in the HF. So, he says, working backwards, if you use that green line as a target response inside the ear when measuring headphones, you will be adjusting the headphones so they sound like flat-anechoic-response speakers.
