Veri
- Joined
- Feb 6, 2018
- Messages
- 9,600
- Likes
- 12,042
...why more?I must have missed that, sorry
Edit: up to 5V only... why not more?
As far as I know X26 Pro cannot run on Asynchronous mode, so D90se is always cleaner?
I would actually like the option to have less since 1-2V is optimal for my particular speaker setup....why more?
Amps like Topping L30 and Singxer SA-1 benefit more from higher output voltage coming from DACs (from my understanding)...why more?
The big question is WHEN Topping will release mono power amplifiers in class AB (with GaN technology?) that will surpass Benchmark AHB2 power amp in measurements and sound?
I am waiting
IT MUST BE DONE, PERIOD !!!!!!!!!!!!!
Who thinks the same give me like
If everything goes as planned, about a week later.
I agree. I'd also like to see these manufacturers (I'm looking at you, Topping and S.M.S.L) spend more time tightening up design review and testing, manufacturing processes, improving QC, and refining existing products instead of constantly releasing shiny new bits to try and keep people chasing the carrot.
I second that...
The new D30pro just released has issues (fortunately not my unit, but other people's units):
https://www.audiosciencereview.com/...-d30pro-review-balanced-dac.20259/post-786784
I have chosen 1kHz to be comparable to Amir Wolfx measurements from both D90 versionsTry 19.3k tone at 44.1k sample rate and 21k tone at 48k sample rate on ES9038, with 192k recording rate. The differences among different filters should be bigger. Specifically, try to find things on 68.9k in the 44.1k result and things on 75k in the 48k result.
Thanks. These frequencies are selected to overcome the measurement limit of your recording interface. Looking forward to see your E30 filter measurements.I have chosen 1kHz to be comparable to Amir Wolfx measurements from both D90 versions
Here are the measurements you suggested. That's only from D10s, mine E30 is not with me right now.
YupIs this Topping's response to Gustard X16's measurements?
I wonder what is the difference between this and dx7pro ...
I mean. Maybe the D90 will have a sync async switch but in the end, the science would indicate it could hardly make for an audible difference.
Thanks for reporting back gvlSo I tested Sabaj D5 against Topping Dx7 Pro, feeding the same signal via USB, the latter running in sync and async modes through the Atom amp, using quick AB switching and now I'm convinced that the differences I thought I heard between the sync modes on the Dx7 Pro were largely imaginary as even sighted I can't detect anything of significance.
