Schollaudio
- Joined
- Jun 24, 2021
- Messages
- 174
- Likes
- 91
I don't know the capability of the Salon 2 but if I understand your asking for 124db at 1 meter peaks I highly doubt those speakers will even come close. Seeing your room you'll want a very nice looking system.This was my intuitive understanding as well. And despite not being an engineer I made the same calculations. However multiple posts by expert engineers, speaker designers and the owner of this website convinced me that I could not get there without suffering some form of compression in cone drivers and could only get there with horns. In medicine we would call this level 3 evidence, or expert opinion, the lowest form of evidence (below randomized controlled trials and oberservational studies). Since I myself am not an expert, and there seems to be a lack of evidence in terms of randomized controlled trials in audibility of dynamics between cones and horns (if there is such a thing), I have to go with expert opinion of everyone that contributed, including yourself.
So, thank you for your expert opinion.
Also, is there any data on the compression of the drivers of the salon 2 at high spl's. I am asking because I have no intuitive understanding of whether or not a 14-in equivalent driver can hit those without compression. Also, in terms of transient peaks of up to 115 DB. How much power will be required and will the driver compress.
Do you know a good carpenter? If so still look at a JBL solution and see if you could get a nice looking custom 18 using a BMS woofers to match the JBLs build. Your still going to want 4 1000 watt amps crossed at 80-100hz and some EQ.
No body complains about the high end JBL 4367 studio monitors. no one complains about https://www.bmsspeakers.com/index.php-10.html?id=bms_18n850v2. A good local carpenter could integrate that setup nicely into you environment.
