ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 4,201
- Likes
- 2,480
@Cbdb2 huhuh OK it's much more complicated and I did gave confusing explanation at first for which I am to blame entirely. I shouldn't do it in the 2 A. M, better yet never (but I ain't that bright). Well what if I am fighting Ohm's low (not really of course)? And amplifier along with any other electric/digital device is. Mind you that's the fight you can not win. Did you ever hear about the term semiconductor leakage, sustainable leakage, exponential increase of leakage? You see amplifier (even your modern digital advanced lithography stuff SoC's, CPU's, GPU's... pretty much everything) works increasing voltage as much as it needs more power to deliver to the point it's permitted as sustainable limit. Transistor will demand more voltage as driving impedance goes up it will do it with voltage rail usually in order of 2x (more rails more times it can do it) and when it can't anymore it will came to voltage collapse hard clipping if you wish. Now it's important for you and others to understand how rail switching is relatively slow so when the impedance drops sharply it will try to retain the voltage and increase Amperage. Now things begin to happen as on higher voltage with higher amperage it will produce more heat as he can't drain that much anymore. As the heat increase also does the impedance, leakage becomes unsustainable and one of many safety mechanisms jumps in to shut it down. I won't even try to explain thermodynamics, diffusity nor dumping factor coefficients in details or scientifically. However who wants to brake his head I won't stop him.
I understand, appreciate and use undervolting benifits along with minimum sustainable voltage and believe me OEM's don't really do a good job regarding optimising it.
Now if you will excuse me I have some serious shit going on right now in my personal life which are far more important than any bulshit including this one.
Have a nice day.
Choice of damping coefficient in Langevin dynamics - The European Physical Journal B
Abstract This article considers the application of Langevin dynamics to sampling and investigates how to choose the damping parameter in Langevin dynamics for the purpose of maximizing thoroughness of sampling. Also, it considers the computation of measures of sampling thoroughness. Graphic abstract
link.springer.com
Have a nice day.
