Thimeo Perfect Declipper
Patrick1958
Belgium
The Themeo Perfect Declipper is a tool used to correct (severe) clipping in an audio file. Someone mentioned it in a topic before, it might be useful to see some measurements and screen captures of the tool's results.
The Song used : Creedence Clearwater Revival : Have You Ever Seen The Rain 24/96 download.
The entire album shows heavy processing (loudness war?) this song from the album as an example clearly showing clipping in Audacity
Below the same song run trough Perfect Clipper with standard settings :
Clearly much better.
DR improved also.
Original file :
After Declipping :
Dynamic range improved by 2 points.
Tested this with the entire album and on two songs even an improvement of 3 points.
I leave it in the middle how much of these improvements are audible. Decide for yourself with your own ears ;)
Veri
The "dynamic range" is improved, because the algorithm fixes problematic peaks, but does it fix what's already messed up in the sound..?
I'm doubtful.
Snarfie
Netherlands
DR improved also.
Original file :
After Declipping :
Did some recordings a few days ago with pictures an audio for download. https://www.audiosciencereview.com/...ighly-compressed-recordings.5923/#post-132926
pos
I just tested that tool on different versions(*) of Norah Jones' utterly clipped "Don't Know Why" title, and I must say I am really impressed with how effective it is!
Of course it does nothing for the numerous digital clicks that clutter this song, but it does audibly reduce clipping artifacts!
You can judge for yourself with these 6 sec excerpts here: https://www.dropbox.com/s/q4ebdo4q16899sw/Declipper test - Norah Jones.zip?dl=1
(most notable clipping passage is on the word "on")
All version are normalized to the same RMS volume within around 0.1dB (gain in the filename, unchanged between original and declipped versions).
Looking at the RMS values of theses excerpts, it appears the 2008 version is 2dB louder than the 2002 one, and the hires version is 0.8dB quieter (and inverted in polarity?!).
(*) I cannot assert for the origin of the 2008 (mp3) and hires (96/24) versions, but I ripped the 2002 one myself from the original CD album.
Dro
It works well enough on simple straight clipping or very hard limiting to just use it as a DSP for live processing. If you want to get into more serious restoration, especially clipping that is tilted, I recommend getting a proper VST host and then running a little DSP chain.
I use this chain:
Stereotool (Declipper)
RX6 De-click (removes clicking and crackling artifacts that might be left over)
Ozone 8 Elements (Compressor)
Stereotool (Natural Dynamics, True Bass)
Ozone 8 Elements (EQ, Compressor)
The izotope plugins are both very user friendly. The point of this chain is consistent performance, even under very bad circumstances. The declipper output might introduce a few very high peaks or strong channel imbalance. The compressor after the declipper will help with that a lot, feeding a better signal for Natural Dynamics to process. True Bass helps with getting some extra punch below 100 Hz, which often seems to be EQed down to allow for higher loudness. Quite often the 100 to 200 Hz range seems to be a bit boosted to make up for that, thickening the sound, so I tend to EQ that down in the second instance of Ozone.
I only gain around 2 dB dynamic range from the declipping and dynamics processing each, for a total between 3 and 5 dB. This may not sound as good as just running default settings and letting it go up to +12 dB, but in practice a consistent dynamic range increase around 4 dB is much preferable to me over freak peaks, channel imbalances and false negatives in the declipper stage.
exaudio
I've been curious about how well these declipper tools work to "restore" the information lost to clipping. I took the clips posted by @pos and loaded them into Audacity to compare the before and after tracks. I wouldn't claim to be able to hear a difference, but to my eye it looks like the algorithm does a reasonable job of "guessing" what the samples might have looked like had they not been lost to clipping.
The top line is the left channel of the clipped track. The middle line is the left track declipped and the bottom is the difference between the two (which I think is what the declipper must have added).
Dro
Looks like a few false positives here. But those can usually taken care of by adapting the settings to the specific track.
RayDunzl
Central Scrutinizer
Riverview FL
Howsabout you try this:
Take an unclipped track segment.
Increase the amplitude to create clipping.
Declip that.
Compare to the original.
pos
The difference is pretty obvious if you listen carefully with descent headphones or speakers, especially with the 2008 compilation version.
I made the test @RayDunzl describes, and the declipped version was different than the original. What this declipper does is not restore the original, but remove audible artifacts by replacing them with inaudible ones ;)
It is not bitperfect by any mean, but it certainly does its job when used on audibly clipped contents like the excerpts above.
Dro
The default use of Stereotool is real time processing.
Dro
Now, while live processing is quite capable for most of the less affected music, here is an example of where the results are not very good.
At the top you can find the original file. In the center, bright, the output of just letting Stereotool run with Declipper, Natural Dynamics and True Bass on, using default values. At the bottom is the output of a more complex DSP chain, also using Declipper, Natural Dynamics and True Bass.
RMS is matched for all tracks. The original peaks at around -6 dBFS. The simple processing result has been clipped at 0 dBFS so we get a better view of the audio. The output of the DSP chain at the bottom peaks at -1.4 dBFS.
You can see that:
  • Simple processing on paper has the highest dynamic range
  • Simple processing also potentially introduces a lot of channel imbalance for peaks
  • Simple processing has very bad clipping detection for tilted clipping, making its declipping restoration inferior and pratical dynamic range is inferior to the complex processing
ryanmh1
Here's a link to another post of mine that has a few album links that someone processed using Stereo Tool. https://www.audiosciencereview.com/...d-why-is-it-happening.3392/page-7#post-152646. This difference this tool makes is phenomenal, in my opinion. Depending on your listening tastes, easily a better way to spend $100 than on pretty much anything else. It seems to magically recover details that shouldn't even be there. But somehow, they are.
I haven't read through the whole thread, but I'm guess that this probably works best with albums that were brutally hard clipped, which probably makes it fairly easy for the software to make very educated guess about what ought to be there. I think it's fair to say that whatever it does put there, the final product is better than the original. Sort of like a map that is missing a piece. You can take a fairly good guess at what should be there based on the surroundings, and even if it isn't perfect, it is still a lot better than just leaving a hole.
Tool
I'm using Perfect Declipper as a vst for Adobe audition 6.0 64 bits, and I'm really impressed. The files I'm sending are logs of Dynamic Range Meter 1.1.1 from foobar. Try to compare it to http://dr.loudness-war.info:
These are files for copule of albums there were compressed around Dr7 and Less, and check the results. Sounds far more better now. I can send a sample sound if someone is intrested.
  • foo_dr.txt
  • (2013) Lightning Bolt_log.txt
  • foo_dr.txt
  • foo_dr.txt
Tool
Unfortunatly Loudness war doesn;t meess up only with pop music like metal, punk rock or alternative but Jazz as well. To anyone who does it keep in mind this picture:
And please stop doing this...
Patrick1958
Patrick1958
Belgium
Impressive numbers. Care to share your thimeo settings?
Dro
It is very easy to get high DR numbers with little audible differences, depending on the settings. DR after declipping tends to be as reliable as a random vinyl rip.
Tool
Let me show you what is a difference between Vinyl rip measurement and cd declipped. System Of A Down (2005) Mesmerize. Just for you to know, I leave every Vinyl Rip as it is, Only Cd's are corrupted and that's unacceptable.
  • Messmerize cd declipped.txt
  • Vinyl Messmerize.txt
Tool
If you ask me about settings I don't change it for cd's rip. So I use only Declipper and Natural Dynamics, but when I need to retrieve sound from mp3 its more complicated.
Tool
Let me show you two exemples what Loudness War does to the Music:
This is 2 albums of Ill Nino band albums original cd rip and after declippiner :
  • (2010) Dead New World Original cd.txt
  • (2012) Epidemia Original Cd.txt
  • foo_dr.txt
  • foo_dr.txt
