This audio cable business is getting out of hand...
DonH56
Monument, CO
OCXO = oven-controlled crystal oscillator. The oven is a little heater to help maintain temperature so frequency stability is better. A lot of test equipment uses them as well (presumably without the mil-spec temperature rating). Makes the oscillator more expensive. I could not say if it has any audible impact. Maybe if your listening room varies from -55 to +125 degC.
MRC01
Pacific Northwest
Despite the ridiculous "audiophile" stuff, there still are some solid companies making well engineered and built cables. Some things I like about BlueJeans cable: excellent parts & build quality, good prices about what it would cost me to buy the parts & build them myself. And one other thing that hasn't yet been mentioned: they build custom orders. Tell them what you want and they'll send you a quote. I've used this a few times, for example to get a Y splitter for 4-pin balanced headphone output, and a replacement cable for my Audeze LCD-2, where the OEM cable costs $150 and is cheap & fragile, the BlueJeans is much higher quality and more durable, and cost less than half that price.
McFly
NZ
Whats the consensus on the W3082 w/banana plugs the same company is listing on Amazon as speaker cable? Looks strange using a coax type setup as a speaker cable, would that not result in high capacitance? I like the look of the banana plugs..
invaderzim
NorCal
It looks cool but the capacitance does look quite high compared to 12 gauge wire.
http://www.mogamicable.com/category/bulk/speaker_cable/pure_sound/
https://www.audiosciencereview.com/forum/index.php?threads/when-12-gauge-wire-is-not-12-gauge.3/
But they do have this quote on their site:
"I was stunned by how dramatically the coaxial 3082 speaker cable affected the sound of my NS-10Ms. I was using good wire before but the improvement the 3082 made was not subtle. The speakers sounded noticeably louder and the response more natural and extended. I had no idea speaker cable could be so significant. Thanks so much for a great solution and a wonderful improvement on my monitoring!"
I'd hoped Mogami was better than that.
McFly
NZ
Well color me sold! But seriously, that's the cheapest I can find speaker cables with that type of banana plug, so I will purchase and let people if they... work. All of my other banana plugs I have here eventually lose spring tension as they get old and wobble around in their sockets, I wonder if these will last longer.
solderdude
The Neitherlands
Did Amir ever receive the speaker cable as discussed in this thread ?
And the LDR volume control for that matter ?
MRC01
Pacific Northwest
... All of my other banana plugs I have here eventually lose spring tension as they get old and wobble around in their sockets, I wonder if these will last longer.
That's why I use locking banana plugs that don't rely on spring tension. With mine, the male plug has metal "flower petals" that expand as you screw it down, though I'm sure there are different variations that are equally effective.
Theo
Any gases that were trapped between the insulation and the conductors during manufacturing are dissipated.
Now I understand where the noise comes from : cables fart if you don't burn them in!:eek:
Sorry, couldn't resist....:facepalm:
SimpleTheater
Woodstock, NY
I'm new here (2nd post) and don't understand the issue. I bought a pair of these about three months ago and listened to a track I was intimately familiar with, The Who's Baba O'Riley. It sounded like garbage. So I left my system on for well over a month playing a loop of music. After the suggested burn in time, actually 184 hours of burn-in, I immediately played Baba O'Riley again and the track immediately opened up, like a veil was lifted. The coherence of these cables are stunning. Bass was booming, when before it was muddy and shallow. I even heard a violin I didn't even know was on the track! Did ANY of you know there is a violin on this track! Well get these cables and hear it again, for the first time.
RayDunzl
Central Scrutinizer
Riverview FL
Not having listened to Baba for quite a while, I can't say I knew there's a violin, but using it for a "never heard that before I put on new cables" seems a bit of a stretch...
Buy that cable again, listen to it new, and I guarantee you will hear the violin there!
RayDunzl
Central Scrutinizer
Riverview FL
Maybe I should have ended my original post with a ;) </sarcasm>
Ok, you fooled me.
My gullibility is only slightly exceeded by my skepticism, and they aren't necessarily time-aligned in their operation, leading to occasional false indications.
Welcome aboard.
