You link is a dead end.That's not correct, Purifi vs AHB2: Link
That's proof?That's not correct, Purifi vs AHB2: Link
Being a 3-way the power handling is better than a 2-way and more power is required for the crossover and drivers as well the efficiency is not high on this model.A Revel F208 utilizes 2 pieces of SB23NBACS45-8, which have 60W rated power handling per unit, so 120W in total. I don't think you will ever need a multi-hundred Watt monster amp for this speaker.
I can be wrong of course.
Low Frequency Extension | -10dB@23Hz, -6dB@27 Hz, -3dB@31Hz |
Low-frequency Driver Components | Dual 8” (20 cm) Aluminum Cone, Cast-frame Woofers |
Mid-frequency Driver Components | 5.25” (13.3 cm) Aluminum Cone, Cast-frame Midrange |
Recommended Amplifier Power | 50-350 Watts RMS |
Sensitivity | 88.5dB |
Proof of that? Say, against a similar low-noise power amp but just as much power as the speaker can handle safely.You will hear a big difference in the low end with the extra power the Apollon provides
Okay, the passive filtering burns some electrical energy, but the low-frequency (where the most music power lies) drivers in the speaker still rated at 60W per unit.Being a 3-way the power handling is better than a 2-way and more power is required for the crossover and drivers as well the efficiency is not high on this model.
The combination of 5 ohms <Z> and –50° at 25Hz means that the F208 will need to be driven by a good 4 ohm-rated amplifier. As Erick Lichte noted, the speaker worked better from his tube amplifier's 4 ohm than from its 8 ohm output.
F208 | 3-Way Floorstanding Tower Loudspeaker
Performa3 floorstanding loudspeakers are true full-range loudspeakers with small footprints and sleek design. They deliver an impressive combination of wide frequency range, uncompressed dynamic range, and low distortion across the entire audible spectrum.www.revelspeakers.comRevel Performa3 F208 loudspeaker Measurements
Sidebar 3: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Revel Performa3 F208's frequency response in the farfield, and an Earthworks QTC-40 for the nearfield responses. The F208 is a large, bulky speaker, so it wasn't possible for me to raise it...www.stereophile.com
Low Frequency Extension -10dB@23Hz, -6dB@27 Hz, -3dB@31Hz Low-frequency Driver Components Dual 8” (20 cm) Aluminum Cone, Cast-frame Woofers Mid-frequency Driver Components 5.25” (13.3 cm) Aluminum Cone, Cast-frame Midrange Recommended Amplifier Power 50-350 Watts RMS Sensitivity 88.5dB
Doesn't the improved power output linearity of a low Z output amp improve everything bass included?Proof of that? Say, against a similar low-noise power amp but just as much power as the speaker can handle safely.
How ~much energy does the crossover burn up? This is something that I have not approached.Okay, the passive filtering burns some electrical energy, but the low-frequency (where the most music power lies) drivers in the speaker still rated at 60W per unit.
Ok. One more time...Proof of that? Say, against a similar low-noise power amp but just as much power as the speaker can handle safely.
Why would Revel rate the power amp requirement as 50-350 Watts RMS<?>Come on guys, please understand, the woofers of the F208 have a combined rated power handling of 120W per speaker. If an amp can deliver this power without too much distortion, the sound doesn't improve if more amp power is available. Even with 120W (or less) from the amp, this speaker would distort and compress significantly.
Because some amps are false specced?Why would Revel rate the power amp requirement as 50-350 Watts RMS<?>
350 real low RMS Watts would eject the woofers I think.Because some amp are false specced?
More amp power usually don't hurts if not pushed to the speakers, just makes your wallet lighter.
I would be curious what this speaker would do if 350 real, low frequency Watts would come from the amp.
Exactly. And I guess the frequency doesn't even need to be lower than the vent tuning frequency for that.350 real low RMS Watts would eject the woofers I think.
This one, or two of these, should do the job, so to speak:Being a 3-way the power handling is better than a 2-way and more power is required for the crossover and drivers as well the efficiency is not high on this model.
Very good point.The Fosi amp has more power at higher phase angles
