THX cinema with pro cinema audio gear
Andysu
Andysu
Comparing a sound scene from The Bourne Ultimatum (2007) on
DVD Dolby Digital 5.1
HD-DVD Dolby TrueHD 5.1
bluay dtshdma 5.1
There are some small subtitles in db level or frequency response when Bourne leaps off a window railing and crashes though a window.
Set TrueRTA to peak hold.
Andysu
Andysu
ultra cheap as fish and chips Technics SH-TX100 early home THX audio soon to be in this lucasfilm ltd THX sound system cinema ,
been watching it for a , no year so now . volume issue doesn't work , that can lose wire , dry solder joint or when looking up part would common part for easy repair
Andysu
Andysu
not played the dvd 5.1 in many , ten , no - years the short clip in Dolby Stereo 4.2.4 felt like an earthquake when ice crave started breaking apart
the low end here is going a bit more vertical THX limit
flutter large sheets . wave large sheets of cardboard . open wave large doors . drop large sheets of heavy materials . get large portions of smoke . get large portions of flames to eventually lose oxygen dissipate with huge large amount of air behind it , inert gases . i think I may be taking this scene a little bit too literal . but it is fascinating and interesting
just thinking of ways acoustically or with maybe the smoke machine to add in some timed effect at certain angles in the room
also i'm light - years ahead of other avr/avp systems , with dimensions below surround is the final soundtier just like an amplifier . once it reaches 0dB that's it , there's nowhere else for amp/surround to go . maybe places outside of the known earth in the universe ? but it's simply not yet been discovered ? although i may dabble in quantum sound physics ? bundles of dreamed images to sell an invention idea that does look fascinatingly , interesting .
Any sufficiently advanced technology is indistinguishable from magic. For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled. I just invent, then wait until man comes around to needing what I've invented.
well the scene in the movie , maybe i get the dvd 5.1 out and give it a listen with the below surround
Andysu
Andysu
led lighting with random flicking lights and sound sync and its made in china lol
Andysu
Andysu
slipping the led lighting between fixed metal screen and screen fabric
Andysu
Andysu
led lighting responding to infersonic lows on my JBL professional cinema subs
Andysu
Andysu
led lighting with non-sync music on stage channels Lc Rc stereo
Andysu
Andysu
laserdisc , psycho III Dolby Stereo 4.2.4 MP / lucasfilm ltd THX sound system JBL professional 40kw
Andysu
Andysu
in this video i be taking a review look at £1 pizza and maybe some immersive audio bubbles ?
Andysu
Andysu
gaumont CIC/UCI experimental overhead surround now up and running in my THX cinema .
after delaying making the other cable lead for few months . the wiring is little complex and had to make sure i do it right . as well as drawing diagram on white board .
this type of overhead surround hasn't been practiced in least this area of the uk , last around 1998 at gaumont/odeon 1 last heard the original overhead surrounds and in 1999 was revamped with JBL 8330 mkI x16 left/right half surrounds .
UCI had their experimental overhead surround i think removed and replaced with left/right half surrounds around 1998 or 1999 as well as CP500 installed and JBL sub 4645B .
so the overheads as i used to know them as hasn't much been practiced now for 25 years and before at gaumont 54 years .
i have to say i rather like the revisiting the overhead surround . denon avc-x8500h can't do it , the trinnov32 can't do it as its a special wiring .
i still have some experiments to do to get the balance , frequency tuning so if i use , atmos mixes on legit discrete atmos mixes for heights 1 2 3 .
the surround signal is being piggybacked from the Sony SDDS system output then sent to ( switcher box ) that has A B C D inputs and single output that is connected to the x3 Dolby SA10 in the main amp rack in the kitchen . the SA10 have to be set to default mode and i have to turn-down-off the amps for DOG 1 , DOG 3 , DOG 3 channels as the SA10 when in default has logic switching that activates for regular surround of the , left/right half surrounds .
i could use the DOG channels with split stereo surrounds .
actually when looking at gaumont/odeon 1 which had middle overhead surround ( mono discrete ) same mono discrete for left right . if anyone can see when using large picture and zoomed in a little bit . i could mimic that by switching off the gain/levels down on certain channels .
mimicking CIC/UCI is almost close as there 4 overhead surrounds each left right of the ceiling , but its very close indeed and i have good sound memory .
if i wanted to mimic gaumont screen 2 that used its surrounds as left/right half and x6 overhead some of the small pictures i can see the where overhead surround as well as pictures may have been taken around very early 1970's before Dolby Stereo CP50 was installed . listened to fair good amount of Dolby Stereo in this , screen all the star wars movies as well star wars also played in screen 1 .
Andysu
Andysu
Technics SH-TX100 preamp Lucasfilm THX made in japan extremely rare
just arrived . the audience is listening . . .
minor repair must have been lose wire or a wire of other . had it been IC chip i would have needed schematic diagram for the repair ? i can only assume this had one previous owner during the early 1990 when home THX became available then got a new lecxicon THX i assume then stored the technics THX until it ended up be sold ?
no remote control for it , most of the controls are also manual on the front panel very easy THX processor to operate
technics SH-TX100 chassis is very well constructed with stiff outer frame and some steel panels for topside , this isn't what you'd get with £28k trinnnov32 after seeing how that is cheaply constructed . technics SH-TH100 THX is heavy and almost a say similar build to its professional ( lucasfllm ltd THX sound system 3417 ) , which , " it can do everything . there's one like it over there " Tomlinson Holman
Andysu
Andysu
Andysu
Andysu
Andysu
Andysu
Andysu
Andysu
did this test with spectrum lab no years ago
soundtrack ( in different languages )
here are samples of different Klingon belches over different versions of laserdisc to region 2 first edition to special edition region 2 to original motion picture collection and Bluray region B original motion picture collection.
when I first saw Star Trek V for the first time at, the Empire Leicester Square presented in 70mm Dolby SR JBL 13KW THX it sounded like, a mild aftershock reverberating though the auditorium that was felt in the seat and over my body.
the output is direct from AVR at 0db level passing directly to the pc.
i have taken tests of centre front and (LFE.1 to see if there is anything within this track.)
some versions show LFE.1 content with less others show less in on the centre front and others even more over the various language types.
Andysu
Andysu
laserdisc
a bridge too far 1977
Dolby surround encoded
scope 2.35:1
seems be interpositive transfer
