Tidal Alternative
X
xirtam2005
Maybe. I run it on an iOS device and can only choose Blues-Folk-Country.
I can try it through Mconnect and DLNA in Oppo UDP-205.
Oppo 205? Nice. I really wish they still made the 205. Do you use it as a source or also as a preamp? What is the rest of your system like?
Timcognito
NorCal
How do you connect Qobuz to your system(s), for good hi-resolution pass to DAC? Any particular settings or additional software, or just native Qobuz apps?
The one problem I do have with Qobuz is the absence of a connect feature. I run mine through ether the BluOS (4 rooms) or Roon. It does let you play and store music on your phone or tablet which I never do. I rarely use it to discover music and if I do I send it to a favorite or play list and pick it up on the BluOS. I'm not the best one to answer as use Qobuz not for their app or connectability but for the the CD/HiRez quality and vast library, very good for Jazz and world music which I like. Others may answer this better. My Node passes digital to my Topping E30 DAC to my YBA amp in my critical listening system.
DimitryZ
Waltham, MA, USA
It does disc and DAC duty very well. Amplification chain is Emotiva XSP-1 and dual XPA-2s strapped for mono and speakers are Eminent Technology 8Bs with two HSU "small" subs.
Eddy H.
Currently have a Tidal Hifi Plus streaming service. Locked in discounted price through a Best Buy sale. Since it is relatively inexpensive, will plan to keep due to its convenience for downloading music on phone for car trips and sounds good enough for causal listening while working or having fun.
However, I just don't like the way it sounded on my very revealing critical listening system. It sounds off, and consider Tidal far more listenable and enjoyable when streamed through a Roku Ultra on a still good quality "midfi" Home Theater system (Marantz AV8802A, Parasound Halo A51). I thought something was wrong with my critical system and looked into Tidal.
There I discovered many issues with MQA being lossy and that Tidal is systematically getting rid of its true lossless bit perfect tracks and anh Hifi streaming of MQA tracks is even more lossy than MQA. They are effectively downgrading sound quality by removing the true lossless FLAC whether they know it or not. Tidal still sounds great to me on midfi home theater gear and a midfi car audio (Acura ELS) for non critical listening, but doesn't cut the mustard for true critical listening.
However I really like the concept of streaming and not having to purchase whole albums or individual tracks, as that would get ridiculously expensive, given the variety I like to listen to. Before Tidal I would play the same physical media tracks on a critical listening system because they sounded good but it got repetitive and wasn't actually enjoying the music. I do enjoy the Tidal music on lower tier gear. It sounds somewhat harsh and flat on the critical listening system vs. Redbook and SACDs.
Is there an alternative streaming service available that offers better sound quality than Tidal? Is Qobuz any good? Is it lossless and does it have a good selection? Amazon Music HD claims to be lossless, but I suspect it is lossy.
Imo Qobuz sounds better than Tidal. I had both at the same time and went back and forth
ThatM1key
USA
There's tools that can download the files directly from Tidal, Deezer & Qobuz. You can put them on a flash drive and plug it into the front usb port of your receiver, no worries of external devices.
jhaider
If that’s the case (and frankly I think it’s likely in your head) then there is in fact something wrong with your so-called very revealing critical listening system.
I recently re-upped Tidal ($2 for 90 days to see if they had new or different immersive content than Apple Music, why not) and it’s fine. The problem lies elsewhere, if in fact there is one.
X
xirtam2005
I'm planning to keep Tidal Hifi, as I'm happy with the content and the interface and still have good use for the service and find that it sounds good to me in most cases. I'm just looking to try if another hifi streaming service, specifically Qobuz, is better for the critical listening system. For your Tidal, do you use MQA DAC or a non MQA DAC?
X
xirtam2005
For those who have Qobuz, how do you get high resolution digital output to an external DAC, if playing from a windows based laptop (USB) or modern Samsung Android phone (USB to HDMI)? Does HDMI limit resolution?
My current DAC is Oppo 105.
VMAT4
South Central Pennsylvania
I subscribe to most streaming services popular here.
Qobuz is great, with one exception - they don't have a separate genre selection for blues - it's together with folk and country, which is a major bummer for me.
Tidal has a much more granular genre selection.
They don't have one for Blue Grass either.
DimitryZ
Waltham, MA, USA
Generally via USB. You can also get a USB to everything converter as well, like this one:
Mini XMOS XU208 USB Digital... https://www.amazon.com/dp/B08HN3VSF8?ref=ppx_pop_mob_ap_share
If you are in the US, I can send one to you - I have a spare.
jhaider
A DAC is a pointless waste to have as a separate component for most applications. I have no idea, nor do I care, if my processor does that MQA thing. My brain is too busy with more important things.
I’m not saying keep Tidal or ditch it. No skin either way. I’m saying that for some reason audiophile imaginations often run wild over imagined slights.
X
xirtam2005
Well in my case the DAC is part of an existing device I've owned for over 9 years that also serves as the preamp and processor hooked directly to amps, so not a waste in my case, but a necessary function.
I'm curious. What is your system and what streaming service(s) do you use? I assume at least Tidal?
jhaider
Main system is immersive with JBL and TAD-Pioneer speakers and multiple subwoofers. Processor is HTP-1. We stream from Apple Music and for the last week or so Tidal as well. I dropped Tidal for Apple when Apple introduced Atmos music with a better catalogue than Tidal offered. But for 2 bucks for a couple months, why not dip the toe in again.
I also use Tidal in my Model Y now, but I assume you weren’t asking about that.
MRC01
Pacific Northwest
On my Linux PC, I connect to Qobuz in the browser, then use the sound card's SPDIF outputs (toslink or coax) to an external DAC. You should be able to do the same with a DAC plugged into a USB port, but I haven't tried it on Windows.
Android devices are difficult because the Android system always resamples all audio. Even from the Qobuz Android app. But USB Audio Player Pro supports Qobuz streaming in lossless HD, and bypasses the Android system audio resampling, and outputs bit-perfect audio to USB. This works great for me.
Two of the reasons I like Qobuz is because (1) you can play lossless HD on any computer with any operating system in any browser, and (2) USB Audio Player Pro supports it.
PS: Qobuz on USB Audio Player Pro is gapless track to track, but not in the browser.
X
xirtam2005
Wow. That is really quite the impressive system, especially those speakers. Do you notice a difference between sound quality streaming Apple Lossless vs Tidal MQA?
Hope you like the HTP1. If my main HT Pre/Pro Marantz AV8802A stops working, the HTP1 and Emotiva RMC1 are top on my shortlist. However very happy with the Marantz for HT usage.
X
xirtam2005
Just signed up for the free Qobuz trial, and all I can say is WOW. I am beyond impressed with the sound quality of Qobuz. That totally fixed my critical listening system! I never knew streaming could sound so good.
Thanks to all for recommending Qobuz. Count me in the Qobuz camp for sound quality alone. Classical music actually sounds good again, especially notice it with high frequency percussion.
