Time Alignment in Speakers
FrantzM
Hi
I would like some clear explanation on what it takes for a speaker to be time-aligned. I always thought the crossover was where it had to start. With first order crossovers being the only ones effectively allowing time alignment. Is it possible through moving (or the different drivers? Could that (Time-alignment) be maintained though the passband by such mechanical means?
DonH56
Monument, CO
<Please bear in mind that I am not a speaker designer, have not built my own in years, and those grad acoustics classes were decades ago.>
Another simple question (albeit a very good one!) with a complex answer. The basic idea is for all frequencies to arrive at the listener at the same time, i.e. in alignment, assuming they all started together at the source. The crossover can be tuned and phase/delays adjusted electrically and/or mechanically to provide correct time alignment whatever crossover order is used. A first-order crossover does not ensure perfect time alignment; far away from the crossover, the highs and lows will be out of phase (sometimes you will see drivers wired "out of phase" in the box and, assuming nothing is wrong, that is one reason why). The drivers and box design (sealed vs. vented, choice of size, etc.) also affect time alignment. Some designs stagger physical positions of the drivers to improve time alignment, but that is also affected by the crossover, since the crossover (as well as drivers and boxes) influence phasing. There is only so much you can do with driver positioning since the phase varies over frequency. Broadband correction these days means DSP since filters and delays can be readily designed in the digital domain to correct crossover and mechanical influences.
How much time alignment matters, i.e. how audible it is, is debatable. I have leaned towards speakers with good time alignment but they have other attributes that I prefer so I really could not say if my preference, or how much of it, is due to time alignment.
watchnerd
Seattle Area, USA
One of the claimed benefits of electrostatic speakers is time and phase coherence across an extremely broad range and physical space.
Blumlein 88
I believe it is true that unless a single or coaxial driver the time alignment will only occur in one direction or plane. Also for large panels the sound will not be in complete time alignment except up close in nearfield because different parts of the panel are at different distances. Quad ESL 63s were quasi point sources using concentric rings. Only a point source would be fully time aligned. Those Quads came close to a point source because the center ring started moving first then the next ring, and the next and so on with delays between. The delay was close to how sound would spread from a real point source in air.
RayDunzl
Central Scrutinizer
Riverview FL
I see measured flatness here - down to 200Hz or so (cross to cone at 180), and projected 10 feet to the listening position.
Blumlein 88
Just a thought. Can you show us a square wave or saw tooth at a few different frequencies? And if not a huge bother at listening position and up close to the speakers.
DonH56
Monument, CO
RayDunzl has previously shared his impulse responses, and they were excellent...
The wavefront from a large planar speaker should be coherent all across the driver, since the panel is driven identically across its surface, and so the part that hits your ears is coherent; the reason for alternative schemes has to do more with dispersion and panel modes than time alignment IME/IMO.
RayDunzl
Central Scrutinizer
Riverview FL
It doesn't really make pretty squares:
Without and with DRC at 80, 250, 2681 Hz, both speakers playing, at listening position
DonH56
Monument, CO
I think the square waves show crossover and other issues between the panels and woofers. The sloping tilt indicates dropping LF response.
RayDunzl
Central Scrutinizer
Riverview FL
Data point:
On thing I was surprised by in the past, was how closely the calculated Step response (from a log sweep tone) matches the recorded step response - here, of the 80Hz square...
From REW Sweep:
From audacity audio recording 8oHz square
RayDunzl
Central Scrutinizer
Riverview FL
The speaker can't "pressurize" this room - how could it hold a level at low frequencies? So, it slopes. The pressure wave it can generate passes on by... The cone may be extended (flatly) but it isn't doing anything to the air when it is extended and motionless.
At 80Hz the cone would have to keep moving out for 6.25ms, then reverse direction for 6.25ms to keep making the compression wave... It doesn't. It moves out according to applied voltage and sits there. That's my thought.
DonH56
Monument, CO
Yes, that is a good thought, sometimes the obvious slips me by. I was thinking more of the shape of the square waves, without DRC, but the response is so good any comments would be taken as nits. BTW, what is "DRC"? The only audio definitions I recall off-hand are "digital/dynamic room correction" and "dynamic range compression".
The excellent matching between calculated and measured step response indicates the time and frequency domains are nearly ideally related. What usually throws them off are modes and/or later reflections that show up in one or the other and require careful gating of the sweeps to provide such close congruence. In the past I have had much better impulse responses than I do in my current system, something I would like to remedy, but just haven't had or taken the time to tweak.
fas42
Australia
As a data point, at one stage I used a cheapy boring box on one channel, and a Technics construction aligned on the other channel, this one:
Didn't cause any audible effects that I could pick - sound stage, etc, with electronics in tune was as per normal.
RayDunzl
Central Scrutinizer
Riverview FL
BTW, what is "DRC"?
It's shorthand version of "Digital Room Correction" which I think of more as "DDSC" as in "Distant Digital Speaker Correction".
It does nothing to "correct" my room, though it does modify the output of the speakers to measure better at the measuring (synonymous here with listening) position, to give the sometimes audible impression of playing better in the room.
Cosmik
If that is an unalloyed good, would you consider BAACH and other methods for reducing the crosstalk between speakers? Your measurements would be even better.
watchnerd
Seattle Area, USA
What are all those tiny holes in the front?
Can't be bass reflex ports...
RayDunzl
Central Scrutinizer
Riverview FL
Not at the price I saw.
$54,000
fas42
Australia
Apparently so. It's the total area of opening that matters, and Technics decided to try this approach on this one it seems - from the late 70's. This pair was used with my DIY chip amps - conventional sensitivity, power handling - still fully operational.
RayDunzl
Central Scrutinizer
Riverview FL
