D10 2019 or D30
  • D10
    Votes: 16 61.5%
  • D30
    Votes: 10 38.5%
La!$
Which has better specs to play lossless music from powered bookshelf speakers? (AudioEngine A5+)
M00ndancer
Sweden
You wont hear any difference. Get the one with the functions you need. (Didn't vote)
Daverz
D10 runs on USB bus power; only USB input; can act as a USB to S/PDIF converter
D30 uses wall wart, has coaxial and optical input, no sample rate display
Silou
I did not know that there is a new 2019 Version of the D10. What has been changed?
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Om
I'm not familiar with these can you summarize it and give mean answer please? Which is better?
The reality is that you won't be able to hear a difference (nothing personal, neither could anyone else). They both offer transparent audible performance, which is all you want from a DAC.
The selection then becomes deciding which has the features you want...does it connect to everything the way you want, etc.
daftcombo
Which inputs do you need?
Only USB from laptop? If so, I asvise the D10.
If you need optical or coaxial in, take the D30.
L
La!$
My speakers have RCA and 3.5mm inputs. So I guess the D10? Also, does USB power and wall wart have an audible difference in audio quality? The D10 has optical inputs too no? Also, 99% of my FLAC files are 24/196. The rest, 24/192 and some DSD files.
daftcombo
No, the D10 has optical OUTPUT. It can be useful if someone wants to convert USB to optical to run a very long optical fiber, to another room for instance. But it has only a USB input.
The D30 has USB, optical and coaxial INPUTS.
L
La!$
Speakers Audioengine A5+
Budget $130
Flac files 24/196 and 24/192
Which should I go for? The D10 or the D30? Thank you for the help in advance!
daftcombo
Budget $130
I have a D10 and I like it very much. If you only need USB input, get a D10.
