Topping D10s + E1DA Cosmos ADC as a measuring system
staticV3
Again: everyone will see an iAP interface with a yellow exclamation mark in their Device Manager, regardless of which driver is used for the Cosmos ADC.
It is fully expected.
Dumdum
Nottinghamshire, UK
The one from the Cosmos ADC's product page: https://e1dashz.wixsite.com/index/cosmos-adc
That's normal. The iAP interface is some kind of workaround from Comtrue for Huawei devices and has nothing to do with the Cosmos ADC's operation.
It can safely be ignored.
Thanks for that, doing that install now, I had a newer version installed, but for trouble shooting I will install that version
Dumdum
Nottinghamshire, UK
Done and installled, just tested and still getting ‘bouncing’
I have also increased the buffers in rew to max to see if that helped any, it didn't
I am just running tests on the same Dsp with the focusrite 8i6 I have as that’s a hair cleaner than the 2i2 and you can just about see the harmonics down to 5th or 6th over the noise and get a SINAD of just over 90db which may be down a little due to noise in the interface I suspect
staticV3
Bouncing is basically guaranteed using the Rectangular window and still likely using Flat top (depends on motherboard and USB cable quality IME).
All other windows should be stable.
Dumdum
Nottinghamshire, UK
So not expected or good with Blackman Harris 4 or 7 then… any other ideas welcome
It does this with two completely different pcs
Lenovo yoga core i5
Hp which is a intel slow thing that’s 8yrs old
Regardless of pc I can’t take a stepped sine measurement without it jumping up before it gets to 250hz
It’s not so bad when you’re taking 1khz sine measurements for harmonics as you can let it run with 32 averages and hit save when it settles
staticV3
Lenovo yoga core i5
Yeah I've had that happen once using a Ryzen Thinkpad, though annoyingly it just sorted itself out at some point.
At the time, my sweeps came out looking like this:
Could you try running LatencyMon on both of your systems?
That might tell us something about the potential culprit behind this instability.
Dumdum
Nottinghamshire, UK
I think the easiest course of action is to flatten the other laptop as it’s not the fastest and use that purely for measurements with a fresh install of windows 10, so that is my next plan
Dumdum
Nottinghamshire, UK
Reset the windows ten second pc with the intention of having it purely for testing… and removed all data bar the operating system and still bouncing… frustrating me this!
Dumdum
Nottinghamshire, UK
So I have got my issue a lot better, by chance I read of someone turning off some network drivers… so by chance I set the rta reading and turned off a bt device, and also the next device under that
I also have changed the power scheme to high performance, and changed the screen saver to 15 minutes on battery and 1hr on mains, this has also helped, I will try and introduce the correct Lenovo drivers for the two items I shut off and see what they do when reactivated with the Lenovo driver and not the windows driver
A positive night after all!
Got the noise floor measurement down to -123db also, and depending on the input sensitivity, had up to -111.6db for SINAD which isn’t far off the AP
chuckt62
Editor
Tejas
Is the Cosmos Scaler an equivalent (+$$$) replacement for the Autoranger?
chuckt62
Editor
Tejas
Yes, that one.
It looks like the Scaler is more gain vs attenuation though.
Dumdum
Nottinghamshire, UK
No problem, I use usual resistor dividers, both SE and balanced configuration, at low impedance (not to add resistor noise), like 1k / 100R and appropriate switch setting on E1DA.
The SE divider + 2.7V EDA setting adds 13x attenuation, so the max. input is 35.1V. Simple math, you can make it as you like.
SE divider looks like this
The Dispre 2 - JFET preamp was measured directly, without a divider, in a setup as below:
So if I want to make a se divider like yours what values of resistors should be used to get roughly 5x the attenuation? So on the 10v setting I can use 50v input which is plenty for what I want to be measuring
I presume it has some reference in the equation to current and also voltage drop through the circuit
lemmy_collins
South of France
R1/R2 should be 5 so 1k and 200 ohm should be OK but beware it will change by downing the setting because of the COSMOS input impedance, for 1.7Vrms the divider will be 6.6 because R2 will be in // with 640ohm input impedance.
