Topping D70 DAC
dannylin
guys, there's no bluetooth support for the D70 , correct?
I thought I saw someone mention about bluetooth but just check on their web site and there doesn't seem to have bluetooth support.
AresHarvest
No bluetooth on the D70. There is BT on the D50s, if you can do without the balanced output.
dannylin
Do you guys know why its coaxial / optical / AES inputs didn’t support DSD?
Snafu
There is an upcoming model D70S that has BT, don't know when it comes out.
JohnYang1997
China
Got this dx7pro measurement from topping. (reminder: this should be A weighted so subtract about 3db to compare to Amir's measurements)
bequietjk
distortion+noise much different compared to Amir's measurements...
maxxevv
Oh that's dx7pro. Forgot to mention. Otherwise I wouldn't even bother to post.
That is almost SOTA. Just need the headphone amp to behave....
And we may have a new price/ performace champ.
Been waiting for it for the longest time since late March.
maxxevv
This does look like Topping's Sabaj D5 killer from that measurement!
They should be more or less on par for performance as far as something build to a price will go. But the Topping one probably has a few extra features such as a dedicated 2.5mm TRRS output and BT 5.0 connectivity. And costs more.
So there is still some viability for the D5 if buyers are price sensitive.
trl
King of Mods
Iasi, RO
View attachment 33018Got this dx7pro measurement from topping. (reminder: this should be A weighted so subtract about 3db to compare to Amir's measurements)
What Amir measured:
Seems that the main difference would be the mains hum. Unless this was induced by Amir's desk/table and surrounding power supplies, then maybe it was something that occurred in Amir's D70 unit only.
L.E.: Just saw @JohnYang1997's post, so this is the DX7 PRO actually, so striking the above sentence.
Jezlar
Newcastle Upon Tyne United Kingdom
The DX7s has stellar DAC performance and includes a good headphone amplifier. The D70 will be in the same case but you loose the headphone amplifier and gain Bluetooth and I2S.
If the performance is significantly better, which would probably make it the best measuring DAC so far, that would certainly make the D70 more desirable. But if performance is a mixed bag compared to the DX7s, then I can't imagine paying more for the D70.
The D70 would have to match the Massdrop THX AAA 789 amp in SINAD for it to be compelling to me. And even then I would have a hard time justifying spending twice as much on a DAC for a given Amp.
Do you or anyone else know how the D70 will pair with a Schiit Jotunheim (no DAC card installed)?
yodog
Anyone know if the Topping D70 Bluetooth Version has the same SNR and performance as the non-Bluetooth version?
Tks
Well the DAC will be bottlenecked by the amp. But to answer your question, it will pair pretty good as it's a very well performing DAC in any case.
No real reason to think it wouldn't have the same performance.
