TOPPING D90 III Sabre DAC Review
Rate this DAC:
    Votes: 12 3.2%
    Votes: 29 7.7%
    Votes: 97 25.7%
    Votes: 240 63.5%
anphex
May be noob question: Will adding a similar budget master clock improve the sound quality from this DAC?
Nope, the clock generatores are already a solved problem and later DACs won't benefit at all from external clock.
DrCWO
Probably not.
You must understand that the best DAC Clock source is an internal XTAL. Even better with temperature compensation.
Why:
An XTAL creates a stable steady frequency for the DAC Clock. Syncing the DAC Clock to any external source or to an external master clock the internal XTAL is turned off and a PLL (Phase Lock Loop) turned on instead of it to lock to this external source. Each PLL is a control loop that detects phase difference between input clock and the synthesized DAC Clock and controls the synthesized clock to follow the external clock. This increases Jitter of the DAC compared to a fixed XTAL DAC Clock.
I never understood why an external master clock should improve sound. It was made for syncronizing several devices in a studio to the same clock but decreases Jitter of the DAC.
Best DrCWO
sandeep_s300
It’s not only about the I/O options available. After having both D70 Pro Sabre and D90 III Sabre, side-by-side, I can say the case quality and touch feeling of the latter is miles better than that of the former.
As for the sound quality, I went by amirm measurements to justify the more enjoyable listening experience I’ve perceived from the D70 Pro Sabre. It’s simply better, more satisfying, listening to music though the D70 Pro Sabre!
Objectively, amirm measurements show that the D70 Pro Sabre exhibits a better Multitone test performance and better THD+Noise vs Frequency, when compared to the D90 III Sabre, since he has used the same - “Linear Phase Fast Roll-off” - PCM filter (not the default one in the case of the D70 Pro Sabre, mind you) in both DACs measurements.
I truly believe that these are the single set of measurements that better correlate with the perceived sound quality, thus if I had to establish a DAC performance hierarchy I would do so based on those two criteria, as opposed to evaluate what’s happening at a single frequency value like SINAD @ 1kHz - not that meaningful if analyzed in isolation!
So, my Monkey choice goes to:
interesting , as I had the D70 pro sabre and have sold a few months back. Wonder if I will hear better quality sound with the D90 III sabre , considering it has dual DAC and better sinad results.
sandeep_s300
Probably not.
Why:
Best DrCWO
Thank you for saving me a few grand :)
Lupin
There would be something seriously wrong with the design of the DAC (or any other DAC) if it would... :rolleyes:
Purité Audio
Industry Insider
Barrowmaster
I am sure somebody has, the answer will almost certainly save you more cash.
MLaranjeiras
This is a review and detailed measurements of the TOPPING D90 III Sabre balanced stereo DAC. It was sent to me by the company and costs US $899.
As you can see, the design is what we have know about most of the Topping products. I do wish at this price that we had a high resolution display that showed VU meters and such. Usability would be better that way although the included remote is easy to use. Back panel is as you would expect:
Nice to see Topping continuing to provide trigger support for automatic turn on of the downstream amplifiers and such.
TOPPING D90 III Sabre Measurements
The DAC has two output setting modes. One that provides max of 5 volts nominal and one that is 4 volts. For fairness I tested using the latter. DAC was allowed to warm up which improved its performance by about 1 dB.
As usual, we start with our dashboard:
This is the best performance we have seen from Topping and is in a virtual tie with the previous king of DAC SINAD measurements:
RCA performance is still superb and fully transparent:
Dynamic range is exceptional as you would imagine as it is setting the SINAD:
Multitone shows the exceptionally low distortion:
As does 50 Hz response for compatibility with other sites using it:
Jitter could be a hair better given the performance elsewhere:
IMD performance is excellent:
Linearity is perfect:
We have the typical filters but I would stay with default (F3):
The filter selection impacts wideband THD+N measurements so I stayed with the default:
Story is told....
Topping aimed to capture the top spot in the rankings and it got there, besting every other DAC it has produced, albeit with very small margin. If the cost is not a concern and you are buying a new DAC, might as well opt for D90 III.
I am happy to recommend the TOPPING D90 III Sabre.
I really like this brand! The question in my mind remains: What do I really get changing my Topping E50 for these flagships from Topping? Also, for the same money I can buy a Lumin D2. Any comments about these dilemas will be gratefully enjoyed.
MLaranjeiras
More specifically I/O options that matter to the person who is looking to purchase a DAC.
There is no audible difference between the E50 and D90 III Sabre, personally the I/O options that the D90 III Sable offers over the E50 are not worth 4x the price of the E50 to me.
This conclusion makes the lauching of "flagships" a pure nonsense, I realized.
Top
