IVX
this is real APU noise + synthetic 1k sine mix.
This is the notch.I posted the screenshot, you can see it, or do you need BW at -3db? View attachment 216423
Could you export this on csv or excel and sent it to me, by any chance ?I posted the screenshot, you can see it, or do you need BW at -3db? View attachment 216423
Mono? It has a specific Mono mode? Or are you just using one channel?So,
here is theTopping D90LE SINAD in 4V Mono
With corresponding plot vs level
Yes but are you merging it yourself? Meaning you are feeding the same signal to both channels and then doing an external merge? Or is there some mono mode?Explained above. I use this method for measurements.
Fair point@Rja4000 , why don’t you switch Y-axis scale to dBr, to get the peak at 0dB? To the unexperienced reader, the spectrum plots might seem overoptimistic.
