Topping D90LE - "Valve" and "Transistor" effects measurements
restorer-john
To add a basically but not utterly irrelevant aside, if I may: ;)
Long, long ago, there was a flurry of "sub-bass synthesizer" products (all analog, AFAIK) that did the same thing, but in the other direction (i.e., added some signal at half the fundamental frequency).
View attachment 214612source: https://worldradiohistory.com/Archive-All-Audio/Archive-High-Fidelity/70s/High-Fidelity-1978-09.pdf
This one may have just been a tone control, though, for all I know.
source: https://www.radioshackcatalogs.com/flipbook/1983_radioshack_catalog.html?fb3d-page=92
N.B. Note that I didn't say these products worked well. ;)
The Realistic Bass enhancer is a great little product. The only real issue with it is residual noise. It's basically a parametric EQ with a very good subsonic filter, so good for both vinyl and small speakers.
It was an add-on sold with Minimus 7 and other small speakers for years.
I've got one here and ran some FR plots on it a while back if anyone is interested in seeing what it does.
mhardy6647
Well... I mean... I would be :)
Not sure anyone else'd care, though... but if you feel like starting a little thread sometime, I'll read it!
restorer-john
Here you go. A few combinations with equal 'db' and 'freq' increments to show the parametric effect.
Bypass (purple) vs in circuit (yellow), no boost. Vertical scale in Volts. Notice the inbuilt low filter- brilliant for small speakers and possible vinyl sources.
fpitas
Northern Virginia, USA
fpitas
... or at least fairly high output impedance.
If it's tweakable, people will spend happy hours introducing more or less boominess. Who am I to criticize?
NormB
I always thought it would be a cool product idea for someone to release a custom distortion generator. Ideally digital in and out so it could be placed in-line before your DAC but analog could also work.
Something that lets you dial in specific 2nd, 3rd, 4th, 5th, etc order distortion just to play with how it effects sound.
Well, there‘s this:
fpitas
