Topping D90SE --> Pre90/Ext90 --> VTV Purifi Eigentakt Stereo Amp
Frank Sol
Thoughts , Opinions and Suggestions on how this trio would electronically interact together. Would they be compatible?
Connections would be via XLR cables
(I am a new member here with this 1st post - Be gentle)
tifune
If you ask him to bypass the input buffer altogether, you'll have a Top 3 measuring amp if not higher. But, you probably won't be able to tell the difference against setups 1/2 the price.
abdo123
Brussels, Belgium
what is the max output of the Pre90?
Frank Sol
Frank Sol
Front End
Yamaha T2 tuner , Cambridge Audio CXC transport & CXN (V2) streamer , PS Audio NuWave Phono Converter and some others
Frank Sol
Frank Sol
If you ask him (VTV) to bypass the input buffer altogether...
I read do's and don'ts about that... Seen where it was not recommended but it has been implemented
Matias
São Paulo, Brazil
Welcome to ASR. This combo should be excellent indeed.
JohnYang1997
China
has the fiasco of the impedance not being optimal for phono stages reached a conclusion?
that's the only measly concern i would have with this setup.
It honestly has nothing to do with phono stage. A proper phono preamp should have line level output with low enough output impedance. Potential issue is using single ended connection can lead to ground loop etc.
If it's to pair with D90se using XLR connection then I'm all for it. For other devices that I have no control over, I can't really give recommendation.
My suggestion would be try it if it works it works, if not then return it.
Shoaibexpert
I am pairing a SMSL SU-9 with a NAD C298 (same tech), why would one need a Pre90 if the D90SE or any modern DAC outputs 4+volts rms via XLR already and you can connect the DAC directly to the Amp balanced without the need for a preamp? Volume control via say D90SE as well!
Any sonic benefits at all, I mean you are adding another component in the chain...there must be a reason:rolleyes:
Experts please chime in...
I have exactly this setup:
bluesound node streamer-optical cable-topping d90se-XLR cables-purifI audiophonics LPA s400 power amplifier -dynaudio heritage specials
sounds addicting and excellent. works fine as a pre amplifier. Small, reasonable affordable and high end system.
4v pre amp is fine, tried 5v but heard no improvement.
topping d90se can not take Samsung tv optical input. Too much jitter. Probably LG same problems.
I solved this problem by attaching hdmi tv output to bluesound node to topping d90se.
now tv sound works flawlessly and delay can be fine tuned with bluesound node.
(bluesound will update soon to usb output for external dac)
Frank Sol
Frank Sol
There are several input units so a switcher of some kind would be needed... However maybe a case can be made that Pre90/Ext90 are expensive means to switch front-end equipment
Shoaibexpert
Hi, I have a Samsung QLED from 2019 and it's optical to my SMSL SU-9 works fine...at lowest DPLL setting btw...
Tried all different cables, but my Samsung tv The Frame 2020 sound keeps stuttering.
I’ve read on several forums that the jitter from samsung tv optical output signals is very high and not every dac can cope with that. Not only topping d90se.
so the problem seems more a Samsung problem than topping problem. chicken and egg discussion.
i am glad I have this solution with the bluesound node via hdmi.
Shoaibexpert
Youre right! The only option that i felt was there in SMSL (and not Topping, I think) is to increase the DPLL setting thereby allowing for more jitter in a signal to be locked. I have that in my SU-9 but never needed to use it...
Shoaibexpert
About matching with Denafrips DACs with more than 1500+ ohm output impedence, would it work well with the Pre90. I know about the 1:10 rule but Amir mentioned in his review that this would only result in voltage drop and no frequency response change...does that apply with the Denefrips Ares/Pontus combo with Pre90?
