guitarshredda15
- Joined
- Jan 28, 2019
- Messages
- 58
- Likes
- 29
Hi everyone,
I have had my DX3 Pro for a year now (V1). Its been great for the most part besides a few quirks such as not working well with my android device and I had some kind of ground loop issue a few months ago where there was a constant hiss coming out of the device for an hour which would disappear when I touched the actual device on its exterior shell (it never repeated that again after that single evening of doing it).
More recently I have started noticing some strange crackling noises coming through my powered monitors and my IEMs which are both plugged into the DX3 Pro, the noises occur at the same time out of the IEMs and the speakers (I just experienced that). It also occurred the other night while I was sleeping, I usually stream music via bluetooth while sleeping and I was awoken by loud crackling noises coming out of my powered monitors. This has been happening intermittently for perhaps two or three months, maybe once a week. There was another incident where this crackling happened and my PC monitors started distorting for a split second at the same time as well (this hasn't happened again). Another issue and I am not sure if its potentially related, the actual power supply of the DX3 Pro is making a repeating-pattern hum that can be heard if you listen closely (I noticed it while fiddling with plugs underneath my desk and it caught my ear).
Do I likely have issues with the power in my house or is something wrong with the DX3 Pro or its power supply perhaps? My PC, speakers and DX3 Pro are all plugged into the same power strip which is plugged directly into the wall (a 3 prong outlet). I cant figure it out and worry about damaging my speakers, headphones and even my PC which is hooked up to it via USB, also not sure if it even is the DX3 Pro. Thanks so much everyone.
