Topping DX3 Pro+ Review (DAC & Headphone Amp)
This is a review and detailed measurements of the Topping DX3 Pro+ DAC and headphone amplifier. It is a replacement for one of my most favorite combo products, the DX3 Pro. It was sent to me by the company and costs US $199.
The DX3 Pro+ maintains the gorgeous and high contrast orange LEDs which I am very fond of:
The back panel is a bit unusual in a good way with sporting dual Coax inputs:
There is a remote and support for Bluetooth. The external power supply is a 15 volt one which should help with power output of the headphone amplifier.
Topping DX3 Pro+ Measurements
Let's start with our DAC measurements and the dashboard:
I expect great performance from Topping and the DX3 Pro+ naturally delivers. Distortion products are at -125 dB worst case which is well below threshold of audibility. THD+N sums to 0.000146 which matches company spec of 0.00015 rating of the company. Converting that to dB, we get our SINAD which comfortably lands in our top tier of all DACs tested:
Zooming into its neighbors:
Dynamic range is excellent:
Multitone test shows again the low level of distortion no matter how many tones we throw at it:
Intermodulation distortion shows that it matches its older brother and then beats it at highest output levels:
The graph never tilts up indicating that it is noise limited, not distortion.
Jitter test shows a bit of interference below 1 kHz which fortunately is completely inaudible:
Linearity is nailed showing excellent accuracy of levels:
A bunch of filters are available for you to play with as usual:
THD+N vs frequency naturally varies with the filter you use:
Topping DX3 Pro+ Measurements THD+N vs Frequency USB DAC Bluetooth Stereo.png
Headphone Amplifier Measurements
Let's start with our signal to noise ratio with headphone out:
I was hoping for a little bit better performance at 50 mv output although what is there is clearly above average:
Most important test here is power output:
Topping DX3 Pro+ Measurements Headphone 300 ohm USB DAC Bluetooth Stereo.png
There is plenty of power and no clipping/rise in distortion.
Switching to 32 ohm load, we still have good bit of power:
Testing at many load impedances tells us that the amp doesn't like very low impedances:
Topping DX3 Pro+ Measurements Headphone Power vs Load USB DAC Bluetooth Stereo.png
This was a good test of the microprocessor controlled protection circuit which kicked in at the lowest impedances. This had been a sore point with the older DX3 Pro and Topping has gone aggressive with active monitoring here.
Topping DX3 Pro+ Listening Tests
I performed all of my testing in high gain and there, the DX3 Pro+ had no trouble bringing out the best fidelity in both Sennheiser HD650 and Drop Ether CX. It drove them with authority, creating a dynamic response with tons of detail and superb tonality. Anyone who thinks these superbly low noise and distortion audio products sound "clinical," should check themselves into a clinic!
For grins, I also drive my Dan Clark Stealth headphone. Here, there was less power than when using the above to headphones but still very usable. Note however that when I cranked up the volume to 0 dB for testing, the amp went into protection. I tried it again but could not duplicate it. Regardless, it was pretty good before it hit that limit anyway.
Prior to this review, I was getting depressed testing product after product with awful performance. Results were so bad that I was starting to doubt my Audio Precision analyzer! Fortunately I had the DX3 Pro+ to test which as you see, not only performed superbly, it also vindicated the audio analyzer! :) This combo unit gives you everything you need in a compact and attractive unit at excellent price. It doesn't have infinite capability as far as low impedance headphones are concerned so for that, you need to step up to myriad of other options from Topping. Outside of that niche use though, the DX3 Pro+ does the job and does it superbly.
I am happy to recommend the Topping DX3Pro+.
Leiker535
L30/E30 just makes less sense now. A good thing overall except for previous owners. Also, makes me wonder why they went for the 3.5mm instead of 6 considering the low impedance limit for iems
Kachda
NY
I almost bought the ex5, glad i didn’t now. Though one wonders what topping has in their back pocket.
Tks
I’m going to use this sometime. Lol audiophiles just got rekt.
Btw do you have the input impedance? That was the whole fiasco with the updated V2 back in the day.
@JohnYang1997 thank you and your team for bringing an iteration of what is arguably my favorite product you guys made. I think the first one was released before you started work there. And I imagine surly the performance boost has been thanks to some of what you brought to the table. Still got a V1 and works great thankfully. Also thank you for the ESS chip this time. Far more sensible filters from my perspective than AKM ones.
I remember you told me how most companies and Topping included avoids DACAMP combos since there is far more profit in selling separates. So it’s nice to see the company not neglecting that segment of the market even if it’s not the most lucrative.
Though I still hope to see Topping tackle RME and implement DSP and more functionality in DACAMPs , or get into the ADC/Interface market and challenge Motu for example. But this works as a stopgap
They document it at 0.1 ohm and I believe it. Otherwise you could not at all get that kind of power into 32 ohm.
musicforcities
It is as if the audio gods sensed Amir was bummed out due to a run of disappointing tests. And verily they spoke, “Despair For Topping brings you good measurements with great value!”
Topping likes their 15v power supplies. First DAC I bought due to ASR review was a D30, also having a 16v ps. Unusual. Wonder why they don’t just use 16v.
musicforcities
Dirac quality dsp room correction unit for $100 including measurement mic.
$165 for balanced I/O
$269 for 7.2 atmos (HDMI & Dolby licensing is not cheap)
I dream. Though I would not put it beyond the realm of topping possibility in the coming years.
Bel Canto
My thoughts are the E30/L30 stack still offers a little more flexibility. Can drive IEM's really well and is not bothered by low impedance phones. Also has a bit more power.
The DX3pro looks like an amazing entry level product and surely has a place in the Topping lineup.
da Choge
DFW
Thanks, Amir, for this favorable review. It seems as if Topping is content on releasing newer and just a wee-bit better iterations of their past successful units; all just to keep us on board. These are interesting, but I'm bored; these may measure and look/perform a smidge better, but NOT really noteworthy as far as discernible listening quality.
I have to wonder, at this point, is Topping just keeping us distracted, with all these "new" releases/reiterations of their past well-enough performing units? And is it maybe at the cost of delaying what we really want -- their long anticipated release of a quality mono/stereo speaker amplifier module? We've all been looking forward to this. C'mon, Topping, if you really want to stay relevant, and keep all of us interested, show us what you can really do.
Budgeter
Finally a zoom in bar chart!!!
Can we also have a channel balance graph? If all goes well, whenever it is sold by or at least ship from Amazon, I will grab one.
phoenixsong
Nice! Amir, just for confirmation, is it filter 3 or 7 that is tested and shows the best performance in the THD+N vs frequency graph?
JohnYang1997
China
The fire at AKM factory means we have to refresh lots of our product line. And the component shortages this year is making things worse. It's been a difficult year for many companies.
In terms of something new. I had been teasing for some time now. A new class D amp is coming with satisfactory performance.
da Choge
DFW
Sorry, John, it's been a really difficult and trying year for me (and I'm sure for many others) as well. I guess I was just hoping for something cheerful from Topping to keep me going. We all want some good news at this point. GAMBARU !!! (Sorry, I know you're not Japanese, but I like this phrase).
