You have another source with an optical output? For example, PC, DVD player, etc.I have a problem with OPTICAL input.
You will be convinced that DX7Pro is guilty of this situation, or your TV is not working correctly through optics.
Then the key, at this stage, lies in establishing what is different about Netflix? Why should Netflix be stable when broadcast TV is not? You say that sound drops out on all broadcast TV channels – and all 'online' sources except Netflix?
In what part of the world are you? The answers might lie in your local broadcast standards.
Sorry to repeat myself, but if some sources are consistently OK and other are consistently problematic, the solution lies in identifying the difference that is causing the problem.
Sorry, I really don't understand that. There's little point returning anything until you have a reasonable clue where the fault is.
In fact, this is not a matter of regional television standards. The signal is output the same for everyone. The point is the product software. If the sound is interrupted, this indicates insufficient data caching, therefore, delays appear. This indicates an incompatible TV transmitter optical output setting."The answers might lie in your local broadcast standards. "
I have a Samsung TV and it does everything it ought, when it should, so your experience appears to be at variance with mine and, in particular, the optical audio output is flawless.I know how bad things are with Samsung
Then explain to him how to properly configure the sound output for optics on Samsung. https://m.youtube.com/watch?v=JaquqPlq6Icthe optical audio output is flawless.
There's nothing to explain. PCM is the default; if that had been changed, nothing would be audible. If you have intermittent audio on the optical o/p, either i) there is a faulty output ii) the fibre is faulty or too long iii) the receiver is faulty.Then explain to him how to properly configure the sound output for optics on Samsung
The most likely issue with optical is that, for some reason, the receiver (DX7) is unable to maintain continuous lock on the signal. The firmware in the TV is highly unlikely to be the cause of this kind of intermittent fault. A firmware problem would usually be indicated by a complete failure, typically high level noise or total silence.Either is a fault of TV firmware or DX7?
It seems like the TV optical output is sending data flow and the DX7 interrupts the stream for a moment, detecting a pause in the middle of flow. Either is a fault of TV firmware or DX7? That's the question.
Which points to the source material as the issue...when i watch Netflix problem doesn't exist
A Topping representative answered you above. Do not use cheap Korean TVs, read the user manual for your TVs,i have the same problem with optical input when i connected to my tv
Lol this is a little extreme..Never buy Korean TVs.
You think very peculiarly. Yamaha rx-v683 is an omnivorous home tool that accepts all formats, from radio signals - AM - FM to 5.1 dts,with my av receiver, yamaha rx-v683
Hello, i just bought mine two weeks ago, and also i have the same problem with optical input when i connected to my tv, an LG, 5 or 6 years old. The interruptions occur both with TV channels and also when i using youtube, but on NETFLIX i have no sound. I don't have any other device with optical output to test it, to see the problem is with my dac or with the tv signal output. Will be interesting to see if the other devices from topping like E30, D50s or other models have the same issue. Another problem mentioned here was with the bluetooth connection, mine is work fine, no drops out, i test it for about 4 hours with my huawei nova 5t, using TIDAL.
