I don't, was just speculating on the theoretical possibility.That's why I put bold on "a". Second, just because there is adapter doesn't mean you should use line out for headphone.
Is ASIO necessary for the DX7 Pro? The Foobar site seems to caution against its use.Windows 10 Groove is an audio player that uses the Windows audio engine.
The sampling rate of all songs is resampled to the sampling rate set in Windows and output. Therefore, it cannot be played back at the original sampling rate of the song.
Your PC's Windows is set to 44.1kHz resampling so it will always play at 44.1kHz.
The Windows audio engine also compresses all songs with a limiter action to prevent saturation in the mixer. So the sound will definitely get worse.
To play the song files under the original conditions, I recommend installing Topping's driver and playing ASIO on an audio player.
Oh I should have specified! I already have replacement cables for my HD6XX that have a XLR balanced jack. I meant for the G560 speakers. Are you saying I should use the XLR 3-pin rather than the RCA or are you saying that it won't matter if I choose either?
I'd recommend you the matrix streamer since it is within budget and it offers a lot of bang for buck. Then you can stop doing all those comparisons and rest easy you got one of the best all-in-one boxes out therewhat I want? I want the best SQ for around 1k$. I will move from spotify Tidal hifi and Wife and kids probably still will use spotify). I don’t need headphones amp. I use only stereo speakers based on Seas excel 8” and Scan-speak illuminator. it would be nice to have BT.
What do youthink about this one, compare to matrix elementI'd recommend you the matrix streamer since it is within budget and it offers a lot of bang for buck. Then you can stop doing all those comparisons and rest easy you got one of the best all-in-one boxes out there
Yeah it looks pretty great, too. It's just very new so haven't seen any reviews, yet.There is also matrix mini on a way. With BT but lower class ESS chip. will I hear a difference? Don’t think so
Seems like a good choice if you're going to play with its room correction... but notice, it has no analog outputs, it needs to be connected to a DAC!What do youthink about this one, compare to matrix element
https://www.minidsp.com/products/streaming-hd-series/shd-studio
I have no time preasure, so I can wait. Matrix mini 3 PRO has USB C instead of old type.
Hmm, haven't seen it that DSP Studio is not a DAC, so DSP Studio is kicked out from my list.
Can we say that DAC level in Matrix mini Pro is the same level like Sabaj D5? Or Matrix is better with ESS chip implementation? Sabaj cost 400$ +RPI4 40%=450$ set, versus Matrix mini pro 970$. double price. I wondering if it is worth... Matrix looks perfect, has everything BT MQA etc hmmm again confused
Mini 3 pro has more functionality BT 5.0, MQA, power supply probably will be linear, wifi 2,4 & 5GHz. element has better ess chip, but in my opinion it will be impossible to hear a difference.Why mini pro and not element i?
Does anyone know why the bluetooth is ON while the DX7 pro is OFF? Is there a why to contact Topping to fix it?
It's standby mode. But the bluetooth module is still working while standby. I think it would be a quick fix for firmware.Is the DX7 Pro switched off via the switch on the rear or in standby mode via the multi-function button on the front?
I am not sure if it's designed to work like this.Having Bluetooth on during standby may be a desired feature. Does the DX7 Pro wake when it detects a Bluetooth signal? (I have Bluetooth disabled.)
