TOPPING HS02 coming
Matias
São Paulo, Brazil
Matias
São Paulo, Brazil
"HS02 supports automatic identification of USB2.0 transmission at low, full and high speeds.
The powerful transmission capability is compatible with high-resolution audio such as PCM32bit/768kHz and DSD512Native. It's available now at US$99!"
kchap
Melbourne, Oz
Most users will not need it but it could be a solution to get around earth loop issues. Another use could be to reduce the load on a computer by plugging in a 5V PSU into the USB C port. The RPI sometimes have problems supplying enough power for a small display, USB3 HDD and a DAC.
HDavidson
Jarrett
So with the HS02 you can change the other end of the output?
Not sure if the further improved latency and isolation voltage are relevant, but I have the HS01 and it greatly reduced the electrical noise coming from my PC.
antcollinet
UK/Cheshire
Is Topping starting to sell snake oil?
How is it you get everything wrong, every time you post?
USB isolators are a viable solution to noise created by ground loops. Assuming this works correctly it will be useful in those circumstances.
dorakeg
