Topping L30 Headphone Amplifier Review
solderdude
The Neitherlands
Is the 'tick' sound coming from the amp itself or is it audible in the head/ear-phone ?
Coming from the amp its normal (but faint).
Coming from the amp try it with the volume turned all the way down as well to see if it is gone.
The higher the efficiency the more likely you could hear a 'tick' in the headphone.
Turkleton
It's definitely not normal neither on L30 nor on THX 789.
Wait, that's not normal? Oh man... My L30 always make a tick sound when I switch it on.
It's not loud, but audible... Batch no. 2010622412
Edit: Stupid me.. Went to test my amp to make sure and didn't read more posts before hitting send.. Mine is definitely the relay clicking *phew*
Azeendeen
Sorry didn't see your message. I just finished typing a long message. Yes the sound is coming from my AMP and not headphones. I feel like I should have made it clear. After turning on my amp, it makes 1 CLICK noise. No clicking noises from headphones
highpurityusbcable
It turns on. Think of it as a greeting.
Aldoszx
All Topping gears I have does this click.
Also Focusrite Clarett does that.
half_dog
Brazil
On my case the tick comes only from the right side (headphone) when the signal comes back after I give it some taps on it. I think it may be a falty relay because if the tap is a little harder the amp keeps working fine for a longer period and if it is not so strong it seems the relay doesn't not make contact right. I thinking about opening this again and do a continuity test on the relays contacts...
Frio
Well the December batch won't be enough to exchange all l30 and many won't do it anyways, so very time the l30 is going to stay in the talks because the blow ups won't stop soon.
Giangi71
However it's a good answer. Professional
