Topping L30 Headphone Amplifier Review
virtua
Their website has some howlers - the E30 page describes it as:
A "small hot hatch" like DAC
which combines meaninglessness with poor grammar. But it just comes across as charming. The exact same sort of thing I'd do if I had to produce some text in a foreign language!
To be fair I understand what they meant by that, a "hot hatch" is a performance car based on a small hatchback platform. Think Volkswagen Golf GTI, Honda Civic Type R etc. The E30 has very good performance in a small form factor which is the comparison they're trying to make - it's "hot hatch"-like. It sounds a bit strange, but compared to the grammatical errors on that apology letter, it comes across much more naturally lol
Blizz
Sometimes when I turn on the L30(2012 series) the light will blink once and seem to turn on with no problems. Is this normal? Anyone else experiencing this?
Yoyop
Yes I have the same thing, only with my 2012 L30, my older one (2008) never did this.
But it works fine, just sometimes the power led turn on, then off for half a second, then go ON normally.
The "clicking" noise when power is ON is happening after the "second" power led
I don't know how to explain, my english isn't pretty good :p
solderdude
The Neitherlands
Might be because of the updated firmware in the processor that handles the relays and LEDs.
@JohnYang1997 will know for sure.
companyja
I wish I knew what makes the L30 warm up, sometimes it's lukewarm when I'm blasting music fairly loudly and sometimes it's quite warm when I'm watching youtube on lower volume (and vice-versa). I don't have something to measure it with but I'd say it gets 40Cish or more, and then it'll cool itself down randomly and get warmer again
solderdude
The Neitherlands
Could be that the 2 output stages inside the output opamp are warming each other up due to differing DC offset and those outputs being in parallel via low ohm resistors. Seeing these opamps are not in unity gain this might be causing this.
Is there a particular spot that gets warmer or is the process very slow ?
Could be some inaudible high frequency in the source doing this.
Could be mains voltage varying in level.
Could be a very, very high low level oscillation.
The thing is reports have been coming in regularly about L30's getting warmer than expected and people stating the replacement runs much cooler (same power supply).
companyja
I'd say it slowly gets warmer and cooler over time and it's the whole chassis no particular hot spot. I remember my old Fiio K5 Pro getting warmer and colder over time seemingly randomly as well but to Fiio's credit, that unit was really only lukewarm at best and mostly cold to the touch. Coming from that massive brilliant smooth volume knob to the L30's knob has been quite a shock but it's something I can ignore because the performance is good. All the L30 front controls wiggle a bit though, just doesn't feel as good as the K5 even though the switches look the same, but hey it's not something I'd consider changing the unit over
SeikON
Should I buy L30 or not. After seeing problems with the product here, I was afraid to buy the L30.
Normally I want to do L30/E30 Stack but after these problems, I consider to buy SMSL M500.
zenki
If you don't have ESD issue, why not but yeah this thing runs quite hot compared to others?
Veri
Both are a good choice really. M500 gets you balanced output if you'd ever need that.
raif71
Iglo
The L30/E30 stack is very nice. There were some issues with the L30 (but replaced under warranty) and solved in the current version. But the SMSL M500 does have some additional options which could make it a more interesting choice (MQA decoding, more inputs, balanced). I would not hesitate to pick the L30 again, but depending on your use-case the additional features of the M500 could make it a more interesting option.
dgnzcn
Turkey
I bought kali lp-6, how can I use it with both headphones and Kali in the l30 + e30 set?
companyja
You can hook the kalis to the L30's line-out at the back, and then use the OFF-HPA-PRE switch of the L30 to switch from the headphones to the monitors
