Has anyone hooked up some powered speakers to this thing yet? Like LSR305 or Edifiers or similar desktop/bookshelf type speakers? Is it really as simple as a flip of the switch to go from my headphone to the speakers? Or do I need to worry about levels like what I read about with the DX3Pro?
It is really simple. I like that the L30 has the knob to switch from Headphones to Pre, without the need to disconnect the headphones, and that you can always leave them connected. And don't be like other amps that automatically turn off the pre section when headphones are plugged in or worse, leave the pre and headphone section on all the time.
BUT
I was testing the E30 + L30 in my dining room, with some Microlab assets that are not the ones I use regularly, I use them casually when I am not in my listening room.
Let me clarify one thing, these Microlabs were connected to the 3.5 output of the PC, before my E30 arrived. The speakers have 60 volume steps, I was using them in step 35. When my E30 arrived, I had to lower the speaker volume to step 22. Without E30, step 35, with E30 step 22, and they sound just as loud. Beyond the significant improvement I noticed in terms of quality and sound much cleaner, warmer, and more detailed, I was also surprised that it sounded much louder. They certainly looked like other speakers. The E30 in DAC mode, because these speakers have remote control, therefore they do not need the E30 in PRE mode.
Now with E30 + L30, placing E30 in Dac, in L30 one knob in Pre and the other in 0dB, and the volume of L30 at height 2 of the clock, that is to say a little more than half, I must also increase the volume of the speakers to step 30 or 32, so they sound just as loud as when I only use them with the E30 and they are in step 22.
The only way to make them sound equally strong with E30 and E30 + L30, is to set it to + 9dB. But I think the cleanest thing is to leave it at 0dB.
In my case, I liked More DAC_Speakers. DAC_L30_speakers i liked less.
The correct way is that? Leaving the L30 in 0dB mode guarantees the cleanest mode, right?
And the active speakers at half volume. What do you guys think recommend? I don't think it is good to turn the speakers to maximum volume nor to turn the L30 to maximum volume. Half volume on speakers and regulate with the L30 knob. What do you guys think?
