Townsend Isolda cable
Status
Not open for further replies.
Max Townshend
Here is an image of the signal generator, set white noise
Max Townshend
No, you have tried to sell it. There's a difference.
In Internet slang, a troll is a person who starts flame wars or intentionally upsets people on the Internet by posting inflammatory and digressive,[1] extraneous, or off-topic messages in an online community (such as a newsgroup, forum, chat room, or blog) with the intent of provoking readers into displaying emotional responses[2] and normalizing tangential discussion,[3] either for the troll's amusement, or to achieve a specific result such as disrupting a rival's online activities or manipulating a political process.
Geert
I have measured the voltages in these two images. Input 55.5 mV and set the y axis to volts. Driven from the monitor speaker output of the 2i2 set to maximum.View attachment 95762
So on the 'flat strip apart' cable we measure 1.1mV @ 10kHz over the cable with a 55.5mV input voltage. That would be a cable loss of 0,17dB @ 10kHz, using a cable specifically crafted to increase cable losses? Do I have the numbers right?
Max Townshend
55mv between red and black into dummy load. Black to black, 70uV at 20Hz, 1000uV at 10k = 23dB. This is similar as shown in fig 3.
solderdude
The Neitherlands
I have measured the voltages in these two images. Input 55.5 mV and set the y axis to volts. Driven from the monitor speaker output of the 2i2 set to maximum.View attachment 95762View attachment 95763View attachment 95763
We cannot conclude anything from the posted plots. Why 2 of the same plots ?
A: We don't know if the dummy load or a resistor was used as a load.
B: mr. Townshend should have made a reference measurement where the input of the ADC should be connected to the output of the amp so we get a real reference in the form of the sweep. The 55.5mV says nothing, we don't know how sensitive the ADC was set, we don't know if the voltage level is referenced.
C: mr Townshend conveniently forgot to mention the cable length as well. (this could have given a clue about calibration)
D: About the dummy load: The posted schematic won't have the impedance posted alongside. Amir's sim is better. Why is the plot from mr Townshend incorrect or the schematic is incorrect (has a Boucherot filter installed ?)
E: Why not a comparo between regular speaker cable and the Isolda instead of the single strip of isolda cable which measures FAR worse that any speaker cable.
SIY
Alfred, NY
Now do “scammer.”
Speedskater
Cleveland, Ohio USA
Again very poor test protocol.
a better plan:
a] attach 'cable under test' from the amp to the speaker or dummy load.
b] with the Fluke measuring across the amps terminals. using a 1000 Hz tone, set the amps output level at 1.90 V RMS.
c] measure the voltage at the speaker's terminals.
d] run a frequency response curve at the amp's terminals.
e] without changing any settings, run a frequency response curve at the speaker's terminals.
f] repeat with another cable.
Max Townshend
The conditions are as described in the paper.
I measured the voltage into the cables with the Fluke 179. It may be +/- 10%
If you want all those answers, do the experiment yourself and get your own answers.
Geert
Where do you see "70uV at 20Hz"? And how is 70uV cable loss 23dB of a 55mV input voltage?
Update/Correction, didn't notice you mentioned 20Hz and not 20kHz (I was focused on 10kHz and higher where you have the highest loss). But the question remains; "how is 70uV cable loss 23dB of a 55mV input voltage"?
solderdude
The Neitherlands
AC voltage on the Fluke 179 is specified only up to 1 kHz. It is not a suitable instrument for this measurement.
For the lower voltages the datasheet even states: 1.0 % + 3 (45 Hz to 500 Hz)
mr Townshend should have made a reference by measuring the input voltage of the CUT directly on the input with his 2i2.
solderdude
The Neitherlands
Why not disclose what you did, mention lengths, use a clear reference ?
How can we repeat the measurements when I don't want to buy 7m Isolda cable and YOU provide the measurements.
Are you being vague on purpose ?
The 55.5mV is pointless as a reference when you use white noise upto 20kHz as the Fluke won't register correctly above 500Hz ...
Totally not scientific at all.
Why not do this with 'normal' speaker cable with the same DC resistance ?
solderdude
The Neitherlands
The plot shows 70uV at 20Hz, the problem is that when this measured voltage is not referenced and the 55mV reference is not correct it says nothing.
Also the cable length is of importance.
When mr. Townshend doesn't provide us with references all math doesn't make sense.
JustJones
I'm not an engineer these other guys/gals are doing a good job of trying to get technical answers I am just wondering why the end of your cable is plain copper wire and cheap terminators?
Geert
The plot shows 70uV at 20Hz.
Didn't notice he mentioned 20Hz and not 20kHz. I corrected my post. Still interested to know how he ends up with a 23dB cable loss, because that huge.
solderdude
The Neitherlands
Without a real reference we have to trust him... Given the track record of being vague and incomplete ... :(
Geert
We don't need the reference as we now have a graph showing voltages. Input voltage 55.5mV, and 1.1mV cable loss @ 10kHz. What's the formula that gives 23dB cable loss using these input parameters?
(There might be some error margin on the 55.5mV input voltage, but that error would need to be really huge to get a 23dB cable loss).
mansr
Hampshire
23 dB is the ratio of 70 mV to 1 V, the approximate graph values at 20 Hz and 10 kHz.
As I've already said, the 55.5 mV figure is guaranteed to be wrong since it was obtained with an instrument incapable of making this measurement.
Status
