Tr-x00 cable question
NemoReborn
Hi. I just bought the tr-x00 from massdrop. Awsome cans. But the cable are wayyyyyy to long !!! Is it possible to cut the cable and shorten it by half? Then either weld a new 1/4 jack to it or cut it twice and weld wire back together.
Im do not want to spend another 100$ to buy custom cable
RayDunzl
Central Scrutinizer
Riverview FL
N
NemoReborn
If you cut it down, won't it be wayyyyyy too short at some future time?
Well , lets say i dont see any situations i would use the 10 feet long cable ! Other than maybe once a year listen to tv with these headphone. But if its the case, i have a female-male 1/4 12 feet long laying around if needed ..
And i already have my ultrasone hfi-780 for this purpose
