Low distortion from 2-8khz (use multi-band compression/dynamic EQ)
Flawless time alignment. (No 4 point systems, use in-line delay hangs). Timing incoherency creates audible smear and makes speech intelligibility impossible.
Flown speakers for even coverage
Club acoustic integration is actually my specialty/career. Feel free to PM.
Wrong. Wrong. Wrong.
Come to the YouTube theater in Los Angeles.
The ultra controlled directivity and meticulously planned array coverage as well as every single wall surface being treated means you can effortlessly hold a conversation within ~103db LAeq15 shows. It’s mind blowing.
Totally Incorrect. The only way this would happen is if the gear and the system designer were totally incompetent, or the room was a concrete bunker with horrific reflections.
No. You hold this opinion because your experience is from point sources being asked to do line array tasks.
You can easily use inline delays. Here is a show I recently did for a ~1600 cap show (50ft x 130ft dancefloor). Flawless SPL and timing gradient across the whole dancefloor. Incompetent engineers give club acoustics design a horrible rep. I’m
