True-Blue class d amplifier using the latest chip innovations from Axign
Julf
Amsterdam, The Netherlands
Are you aware of the Axign chip innovation for class D amplifiers going on in the Netherlands?
So what is innovative about their class D amps?
BillG
Auckland, New Zealand
Are you aware of the Axign chip innovation for class D amplifiers going on in the Netherlands ?
If you're referring to the Pulse Width Conversion technology that they're using and referring to as a "Power DAC", Texas Instruments has been doing that on a number of their Class D amplification chipsets for awhile now. I've a ~$120 USD integrated amp from a Chinese company that utilizes the technology in the form of the TAS5548 chip... :cool:
scott wurcer
Audio Luminary
restorer-john
The Baltic birch sandwich
I read that and thought "he ships sushi from Japan for lunch and now Baltic bird sandwiches? What is he? Gordon Ramsay in disguise?" Then I saw birch...
Had some o-toro flown in from Fukuoka market yesterday, it was only a small sample but I didn't have to pay.
BillG
As a visual artist, as well as a scientist and engineer, I appreciate good design. However, this isn't doing it for me; If I'm paying over $1,000USD for an integrated amp, I don't expect it to look like a stack of unfinished plywood... :oops:
Julf
Lookin like some avant-garde joke in terms of the enclosure..
Someone got a laser cutter for Christmas...
KSTR
Berlin, Germany
The feedback. Normally, a class-D amp has an internal analog feedback path to make the amp work. but here the feedback signal is digitized (with an ultra-fast ADC), can be processed/filtered digitally and control PWM output pattern directly. This allows for much higher loop gain in the audio range, for lowest distortion and low output impedance. Basically the same thing that Bruno Putzeys did with the Ncore in analog. Also, it is very easy to install arbitrary output impedance profile because the chip has multiple parallel layers so you can have a voltage- and a current-based feedback signal and process/mix them in digital. Very handy for active speakers....
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Looks like something I would have made out of ice cream sticks as a kid...
Ron Texas
I would think making the case out of Popsicle sticks would be more interesting.
