Tube Question
Ja1man
Where did you read this?
Its mainly hearsay and plus these two places:
Phorize
U.K
I get a warm feeling knowing that we’ve had near audible transparency in consumer grade valve designs since 1947.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Remember when fidelity was a prime selling point? They were trying to eliminate distortion...not turn it into a feature.
Ja1man
Clearly, some things do sound different. If its due to topology or implementation, that is yet to be seen.
fpitas
Northern Virginia, USA
Then came SETs lol.
fpitas
Right? Push-pull is a dirty word now. Gotta have that massive even-order distortion.
fpitas
We're talking overdriving amplifiers for instrument use? Yes, tube amps do overdrive differently. There's no mystery, you can stick a 'scope on the output and see it. Needless to say, that is not hi-fi. That's the art of designing a tube guitar amplifier. I won't go into details, but you do a lot of things that you wouldn't do for a hi-fi amp.
Ja1man
Here's how about this.
Yes, none of these products are that good. Even the woo audio is not a SET. This is why they sound so similar. But clearly there's enough of a difference to warrant going to a store and trying out different things and seeing what you like. Surely.
fpitas
And these amps measure similarly? Because that is to the point everybody has been trying to make: you can measure the differences.
Ja1man
And I'm trying to say you can hear the difference instead...
fpitas
Them I'm not understanding you. Are you saying they measure similarly? Because if they don't, that's the logical explanation.
GXAlan
@AMKAM
if you want to try some added warmth for free if you are running Windows, get Sony Music Center and try the DSEE HX processing.
While it adds higher frequencies to the music, it also adds harmonics.
It’s free, you can measure differences and you can ABX it. Whether or not it makes things worse or better is up to you.
fpitas
fpitas
Aha, you were talking about SETs.
The transformer with a gap in the core, heat, heat, heat ...
Yup. Even-order distortion from here to forever. And very low power.
Ken Tajalli
London UK
I have a pair of circlotron OTL tube amplifier monoblocks (DIY) that sounds pretty good with two 6C33C tubes about 30W and over 50 with four tubes.
Requires lots of feedback to keep the circlotron to behave.
I am very happy with the sound, but it is OTL, it means constant checking and servicing - with my back problem, I have them in storage these days, and got myself some used Meridian poweramps.
Much easier, plug and forget.
fpitas
Atma-sphere makes some nice OTLs, too. Lots of balanced differential stages etc. If I had to own a tube amp, one of those would be it. Luckily, my First Watt J2 sounds fine to me. And it never needs new tubes.
Ken Tajalli
London UK
I believe mine is similar to the Atma, with a difference.
The phase splitter on Atma has a tube constant current source, an elaborate one, mine is just balanced input.
I rely on DAC preamp output to give correct balanced signal.
Mine has few 1000 hours on it, output tubes are still good.
But those 6C33's can suddenly go out of spec. for no reason. I don't run them too hot, and cooling is good.
I have had two tubes sort of fail on me. and they vary too much from sample to sample, so I build myself a tester just for 6C33C's as I couldn't find one already built.
