Wendigo79
- Joined
- Apr 27, 2020
- Messages
- 52
- Likes
- 25
Here are two Equalizer APO files for Moondrop Sparks. I find them pretty decent without eq, but wanted to try to improve them with eq. As the preference target I used a combination of the Harman and the IEF-targets. The bass response is taken from the Harman model. In first one the bass response is made to the exact spec of the Harman, but in second one I reduced the bass response, as I find Harman's bass response often too powerful. The upper range is in both from the IEF-target. I used crinacle.com and it's exellent tool and measurements when making these. The second one, with lighter bass is my own favorite.
Moondrop Sparks JunnuBoi special 1
This is the one with heavier bass.
Preamp: -5.9 dB
Filter 1: ON PK Fc 21 Hz Gain 0.6 dB Q 2.000
Filter 2: ON PK Fc 35 Hz Gain 2.9 dB Q 0.500
Filter 3: ON PK Fc 240 Hz Gain 1.0 dB Q 1.700
Filter 4: ON PK Fc 750 Hz Gain -0.5 dB Q 1.000
Filter 5: ON PK Fc 1200 Hz Gain 2.6 dB Q 1.500
Filter 6: ON PK Fc 2000 Hz Gain 0.5 dB Q 2.000
Filter 7: ON PK Fc 4300 Hz Gain -2.5 dB Q 0.800
Filter 8: ON PK Fc 5500 Hz Gain 0.5 dB Q 1.800
Filter 9: ON PK Fc 6700 Hz Gain -2.5 dB Q 1.700
Filter 10: ON PK Fc 11000 Hz Gain 6.7 dB Q 1.900
Moondrop Sparks JunnuBoi special 2
Preamp: -5.9 dB
Filter 1: ON PK Fc 21 Hz Gain 0.8 dB Q 2.000
Filter 2: ON PK Fc 35 Hz Gain 0.9 dB Q 0.500
Copy paste these to a text file and use on Equalizer apo.
Alternatively just type in to the UAPP parametric equalizer. UAPP will take care of the preamp automatically. So no need for the first line (the preamp)
Happy listening!
Preamp: -5.9 dB
Preamp: -5.9 dB
Happy listening!
