UDIO-8 with Audiolense getting started routing, speaker check connections.
Trdat
Yerevan "Sydney Born"
I know this is niche but I am hoping a few people might have experience with the UDIO-8 with Audiolense. So far I have set the UDIO-8 in ASIO4ALL as playback device and my external sound card/microphone as recording device. And then chosen ASIO4ALL in Audiolense as both playback device and recording device. And no sound in check speaker connections. I have also enabled output channel override.
I have the PC>UDIO-8>two separate DAC's one for high frequency and the other for low> into two separate amps > woofer and compression driver
All to no avail, just can't seem to get any pink noise for the speaker check connections. Any ideas?
I can't imagine it being different from a multichannel DAC.
Kal Rubinson
Industry Insider
NYC
Have you tried bypassing Audiolense and running Jriver directly to the U-DIO8 with the proper ASIO drivers? That would assure you that the hardware is functional. Perhaps Audiolense needs to see the miniDSP ASIO driver rather than ASIO4ALL?
Trdat
Trdat
Yes I have, I got the UDIO-8 routed within Jriver and I've made it work. I can try with it routing the playback device in Audiolense through Jriver or by using the minidsp driver instead of ASIO4ALL might have a chance.
