Unusual Speaker Designs
andreasmaaan
That particular null is relevant only to the bats and cats. :D
At 15° off-axis, yes. But look at how it moves lower and lower down in frequency as one moves further off-axis.
QMuse
After 45 deg I don't think they play a major role in our perception, and that one is at 7kHz. Not very good, but not a complete disaster either. My bet is that it would sound better than it looks on the graphs.
andreasmaaan
What are the benefits exactly?
HammerSandwich
What your explanation has glossed over with the respect to the Sony, however, is that the output from the "assist tweeters", having a centre-to-centre distance of approximately 3.5cm, will interfere with each other destructively even small distances vertically off-axis.
Can't all 3 be integrated into a coherent array with amplitude shading and/or delay on the assist pair? Advantages compared to a single tweeter would include vertical control to a lower frequency, lower XO point, better tweeter SPL/THD on the low end. If that's Sony's approach, they could produce much better results with this new DSP speaker than with the passive that Stereophile measured...
LeftCoastTim
I think tweeter-woofer bookshelf design are like cars--it is the result of many decades of iteration that settled on a near optimal compromise. Sure, there are 6 wheeled cars, 3 wheeled cars, cars with rear wheel steering, all wheel drive, rear wheel drive, 2, 4, 6 seats, whatever.
But globally, most popular cars has four wheels, front wheel drive, four cylinder engine, in a two or 3 box configuration.
The research on sound reproduction says flat frequency response and wide directivity sounds the best, and it seems like 2-way bookshelf can deliver that at low cost.
Efficient? Yes. Boring? Yes.
Personally, I like boring and efficient. The most exotic thing I own is a Kinesis Advantage2 :)
Wes
That is OK. I tend to reply as I did when anyone criticizes a statement made by a Stereophile writer and attributes it to many or all of us. A sensitive point for me. :)
Let's say there is a very wide range of writers in that publication...
Archsam
London, UK
I tend to agree, and it explains why most of the speakers listed in this forum are of the type that beg you to ask: do I buy these speakers, or a Ferrari?
mhardy6647
GelbeMusik
These alternatives are mutually exclusive. Ferrari, by intent, makes bad hearing. (Just try.)
Wes
not if it's broke
and, usually....
mhardy6647
How good WAS the DQ10 BTW?
meh, IMO.
Used the same woofer as the "Original Large Advent", some very good mid and treble drivers, and the Motorola piezoelectric "lemon juicer" tweeter.
They benefit greatly from LF augmentation (and Dahlquist sold a subwoofer for them) and they were (are) extremely power hungry. Dollar for dollar, I much preferred the Polk "Monitor Series" of the same era, which were much cheaper, and the ads/Braun loudspeakers of the day, which weren't so cheap but which were extremely satisfying loudspeakers, top to bottom.
The DQ10 was also quite deliberately designed to look like Quad's seminal "ESL-57" electrostatic loudspeaker -- that always bothered me a little bit, too.
AH477etc by Mark Hardy, on Flickr
Soniclife
andreasmaaan
It would definitely work better with amplitude shading and delay, I agree.
To your specific points:
  • Even combined with delay/amplitude shading, three is not a large enough number of drivers in the array to yield coherent/useful vertical directivity control.
  • The "assist tweeters" have 14mm diaphragms. I find it impossible to imagine they allow the central tweeter to be crossed over any lower than it otherwise would be.
  • Similarly, I can't imagine they improve SPL/THD on the low end either.
Moreover, if they were using such an array on a passive design, I'm inclined to think it remains marketing BS now, as it must have been back then.
I do accept that they would likely widen horizontal dispersion at very high frequencies, but that isn't listed as a design goal.
HammerSandwich
I can't argue with most of that.
A 3-driver array still strikes me as able to control vertical dispersion significantly. Consider a ~4" ribbon tweeter's vertical lobe. But I hadn't realized the 14mm size - that's unlikely to to help anything else, and it's a bizarre design choice for an array that uses more drivers at lower frequencies. And if Sony's using a different kind of array, well...
I believe we're on the same page about this design, but perhaps the measurements will astonish us.
andreasmaaan
You'd want them to for the price tag :)
But actually, I'd love to see it measured. I suspect they've done as well as they could have given the interesting design choices.
