So at the moment my setup is pc-> Focusrite scarlett 2i2-> Adam audio t5vs. There seem to be background noise and ticking that gets even worse if I play any games, and the right channel is much louder than the left (not the speakers, I switched them to check) which is really weird. Also, it feels like I really need to crank up the volume knob on the Scarlett to get decent output from the monitors. I’m new to the audio world so I’m not sure if the issue is my pc, the audio interface, or the monitors but I assume it’s the interface.
Im thinking upgrading to one with optical input and it’s own power supply might fix the issue. I’d like to find a solution that would allow me to connect my pc and turning table to my monitors. Is there an all in one solution or should I get a dac and amp separately, and if so which ones should I get? Do the monitors need an amp or a preamp since they are powered? I’m kinda lost in all the terminology and information out there.
Thank you for the help
