If you have identical mains properly set up and aligned, you don't really need Center Spread.
CS is really there to make inferior "center channel speakers" sound better by mixing in the better quality L/R Mains.
I have identical LCR here and the setting sounds the same from the MLP with it it on or off and definitely worse off-axis due to it pulling to the closer speaker (Haas/Precedent Effect).
In fact, I see zero point in having the center speaker on for music at all if you're just going to mix in the mains. I suppose there's less Precedence pull than none, but it's still pretty bad off-center, IMO.
As for upmixers, I've been playing with a Lexicon MC-1 plugged into my Marantz 7012's 7.1 inputs (the 8015 is the last model to feature 7.1 inputs and it's on sale right now as it's being replaced by the Cinema30) and all I can say is
Logic 7 blows the pants off everything out there when it comes to 2-channel to 7.1 upmixing.
You never knew what PLII was going to do with music. Some albums sounded interesting, but most just sounded odd, IMO while Logic 7 almost never sounds odd or bad. I disagree it's just ambience. I'm getting pretty 3D sound with some albums like Tori Amos' Ocean to Ocean, particularly if I add side heights to mirror my front stage "lift" effect at the sides too.
I use "Scatmos" to extract front wides and ss#2 (which also works with the Lexicon)(as well as full Heights+Tops using reverse polarity extraction on a couple of Marantz NR1403 half-height AVRs) and setting the Yamaha HTR-5960 (front wide extraction AVRs) to "Neural Surround" decoding while leaving the arrayed copies pure (Y-splitter before the extraction AVRs) gives this incredible vertical image spread very similar to what Neural X does with movies. I think the two are related as DTS bought Neural Surround and then developed Neural X next. In Star Wars (2-channel 1977 Dolby Surround track), the bits where C3P0 looks up and asks what was that imaged at ear level before, but with this effect, it images high while other sounds image low just like with Neural X. Neural X is probably more accurate, but it doesn't work with 2-channel sources very well, IMO so this offers a nice alternative. DSU is somewhat better, but it just sucks with 2-channel music, IMO.
Overall, I find Logic 7 to be the perfect balance between ambience and upmixing for 2-channel sources. It does pretty well here with 5.1 sources as well (Toy Story 2 where Al from Al's Toy Barn runs down the left wall saying, "Buck Buck Bucks" and laughing moves smooth as silk here with Logic 7 down the left wall and over to the center rear. With THX EX (really DTS-ES matrix), it moves part way down and then "jumps" over to the rear center as it's mono. With Logic 7, it's one smooth motion. Neural X can achieve the same effect here with front wides and ss#2 extracted, but it's impressive that technology from 1999 can manage 75% of the Atmos effect (Neural X maybe 90%). But for 2-channel, it just can't be beat, IMO.
Auromatic is OK for music upmixing, but you have to crank the mode and adjust the increased bass (amazing they couldn't figure out how to do that automatically in the driver; that blows my mind as it's so amateurish), but it's really just an ambient copy/reverb mode. It doesn't "move" anything whereas Logic 7 does (maybe not as violently as PIIx did, but then PLIIx was hit and miss with music, IMO as it can move things you expect in the front to the sides or rear sometimes). Part of Logic 7's appeal is that it
doesn't move the front soundstage at all and it's more gentle with out-of-phase effects.
Given the combined Neural Surround with Front Height and Surround Height matching and Logic 7 along with Scatmos Front Wide & SS#2 here giving me essentially 15.1-channel Logic 7 (aka Logic 16), it's hard to comprehend why HK has had so much trouble getting Logic 16 to work properly. I think I get the full intended effect here using technology no newer than 2005 (the Yamaha Neural Surround upmixers) beyond the Marantz 7012's "7.1 input" mode to host it within my Atmos/X/Auro-3D system.
I
could still add Pro Logic II (either by getting a used MC-12 or using my existing extra Yamaha HTR-5960 AVR (same ones used for front wide extraction with its Neural Surround mode), but that would mean I'd have to ditch my trusty old laserdisc player to make room for it (whereas the MC-1 fits nicely on top of it). But the Yamaha has its own 7.1 input mode, so technically I could keep the MC-1 and have both plus the Neural Surround mode, but I'd need to duplicate the Nvidia Shield digital outputs for the best connection to both (I could easily do a RCA split to both as I already have RCA into the MC-1 for the Panorama mode and DSP modes as they require either analog or 44.1kHz inputs and KODI on Android Nvidia Shield doesn't like to do 44.1kHz output without a fight. It was easier to just throw some analog connections in as well from the device extracting the digital toslink output). But frankly, I'm quite pleased with Logic 7 for 2-channel music and movies.
As for room correction, the key is to go external with a Mini-DSP. It can control 4 subs instead of the 7012's two or three plus a seat shaker output. I'm not a big fan of correction above Schroeder anyway so it works quite well.
My Home Theater Racks are shown below (The Lexicon MC-1 sits just below the Marantz 7012; the NR1403 units are on the 1st rack and the Yamaha HTR-5960s are in the right rack with Onkyo-ES600 units for SS#2 on the bottom below each rack). I've got the Nvidia Shield and Zidoo X9S both going to the Lexicon MC-1 (optical and RCA) as well as to the Marantz 7012 (HDMI). I could plug the LG Blu-Ray player into the Lexicon as well via its optical jack, but I almost never use it so I haven't bothered. The laserdisc player has only one optical output so it's connected to the 7012 for the occasional DTS laserdisc, but it has a 2nd set of RCA outputs that can be sent to the Lexicon as well as the old GameCube, which benefits from Logic 7 as well; the PS4 goes to the 7012 via HDMI).
There's also some Monoprice impedance matching switches on the right top that let me copy rear heights to surround heights and some other neat tricks. Auro-3D has the Tops speakers carrying the VOG dual mono signal in quad while front/rear heights handle the rest with optional surround heights arrayed from the rear height signals. In total, there's 21 speakers connected (11.1.10 in a 12'x24' room with 3 rows of seats). I plan ot try some floor effects next once I get one more set of PSB speakers in using the Front Wide extraction surround outputs (out-of-phase ambience will go to the floor instead). That should give a more spherical soundstage instead of a dome.
View attachment 353428 View attachment 353429
