A man after my own heart.
So what does this mean? My sense is that the layout and implementation of USB in Iso Regen is sub-optimal and not tested (or tested but not disclosed).
Hi Alex. I don't see anything about Silanna isolator chip there. I have looked twice now to find specs for it and none exists without contacting the company and signing an NDA.No, it means you don't understand the Silanna isolator chip.
https://www.computeraudiophile.com/...-a-dacs-output/?do=findComment&comment=705472
woud it be possible to have one of these devices fitted with a bypass switch ? That might make things easier with minimal fussing about when doing the listening test, I'm not sure if it would work but there would be benefits if you could quickly switch between no ISO regen and ISO regen..
Honestly you will waist time and money, we went from a distortion device (Regen) to an isolation device (iso Regen).
We are talking about asynchronous mode, remember so re-clocking, regenerating, blabla is just marketing BS.
The only way to have an effect is to be outside the USB specs like the lush from peterST, a delay you create DCD and you make the DAC oscillators singing the way you want.
I have to say the 'lush' USB cable thread( lush in the U.K. Also means alcoholic) is some of the finest shilling I have seen for quite some time.
Bravo!
Easiest to buy a second $79 Behringer, feed them both the same stream, one with the ISO in the middle, and switch between two inputs on the preamp, no?woud it be possible to have one of these devices fitted with a bypass switch ? That might make things easier with minimal fussing about when doing the listening test, I'm not sure if it would work but there would be benefits if you could quickly switch between no ISO regen and ISO regen..
Not sure about that. Does USB audio signal flow from the PC software driver to all output USB ports (two in this case) on the PC or on a USB hub simultaneously or is it specific to a single USB output port via a "handshake" after DAC connection is established? I realize I can hook my single DAC up to any USB output port and the driver will find it and connect. But, with two DACS, I am confused. I wonder if the driver and USB might get confused too. Has anyone tried this?Easiest to buy a second $79 Behringer, feed them both the same stream, one with the ISO in the middle, and switch between two inputs on the preamp, no?
But, yes, switching the analog in a preamp should be quicker if it will not disrupt the digital stream.
You sure about this? Seems I tried doing that with Windows not long ago, and you couldn't send to multiple devices that way.If you have Stereo Mix enabled you can send out to multiple sound devices.
On your #1 theory, here is the measurements I just made with the AC plug in one direction and then the other on the Insignia Hub as opposed to Iso Regen:
As you see, there is no difference in the DAC output whether the Insignia AC adapter is plugged in one way, or the other. The Iso Regen still remains as the only device that is inducing this mains frequency into the chain.
Let me ask you this: prior to my testing, had you done similar measurements, saw the same leakage and investigated it? Or is all of this new to you?
