USB audio interfaces interest
What USB audio interfaces do you want measurements made of?
  • Swissonic UA-2x2
    Votes: 27 9.2%
  • Midiplus Studio M
    Votes: 5 1.7%
  • Presonus AudioBox iOne
    Votes: 17 5.8%
  • Focusrite Scarlett Solo 3rd Gen
    Votes: 150 51.0%
  • Audient iD4
    Votes: 68 23.1%
  • Steinberg UR22 MK2
    Votes: 70 23.8%
  • Roland Rubix22
    Votes: 30 10.2%
  • Presonus Studio 24
    Votes: 32 10.9%
  • Mackie Onyx Artist 1.2
    Votes: 16 5.4%
  • Icon Cube 4nano
    Votes: 3 1.0%
q3cpma
q3cpma
France
The german description of the Swissonic UA-2x2 sounds like they just repeat the DAC and ADC Spec sheet numbers.
That wouldn't suprise me, sadly. But I want to believe in them because Thomann is pretty honest/good in my books. I'll try to email them for more specs.
And ask them to send in a sample for review! :)
kn0ppers
Germany
Definitely not worth it to send back and forth.
Yes that's pretty much what I thought. Maybe a user living in north america owns one. I would definitely like to see some entry level recording interfaces tested. The one I mentioned is quite a versatile device, although I do not use it very often.
somebodyelse
Given the periodic queries about interfaces for recording or measurement it would be good to have measurements for the ADC as well as the DAC part. I'd like to see one with more outputs for active crossover use too.
kn0ppers
Germany
I think we do have some. I believe the A/D-Conversion was measured on the ADI Pro-2 and a Creative Soundblaster usb-soundcard. Maybe there are even more?
mansr
Hampshire
I'm not against A/D measurements, but we'd need some reference to know if they're good or not.
That moustache graph above was from the ADC of the UR242. The DAC output looks the same since they share the clock.
HammerSandwich
Amir's AP tests will characterize the device's DA performance, right? Won't loopback tests then let us judge the AD section? IOW, we might not have the AD's full measure, but we should know if the total device can handle REW, etc.
Reinhold
Germany
the new focusrite range has a headphone out impedance <1ohm according to their datasheet :eek:
thats amazing right?! but the dynamic range looks a little weak with 104db.
We have a few data points including the excellent ones above. And of course the ADC built into my Audio Precision analyzer.
q3cpma
q3cpma
France
You're right, I didn't notice this gotcha. Well, I think that Solo measurements will also stand for the rest of the lineup, unless the chipset changes (maybe a better preamp for the headphone?).
LTig
Europe
Didn't consider the Mackie because I don't know them very much and their speakers aren't well spoken of.
Cannot second this. I have a pair of Mackie HR824 (old version, inherited, currently used for Webex :eek: in the office 'cause no one in the family wanted to have themo_O) and they are not bad at all. The K&H O300D are better in several aspects (precision, off axis response) but they cost much more, and I could well live with the Mackies if it's necessary. Also me and my brother both own a 1402 mixing console and they are reliable and deliver good sound.
The Yamahas are considered very good (personally, Yamaha is one of the only brands I blindly trust) but I obviously won't include such a big and complicated mixing table-like interface as a "casual hifi DAC".
I'm interested in the Yamahas because they have an ADC. Makes them ideal for measuering room response.
peder2tm
I am interested in headphone measurements of the clarett 2pre. Most of these usb interfaces have low output power but the clarett 2pre seems to be a good candidate for an all-in-one box.
JohnYang1997
China
I can tell you it's ok. But not powerful for low impedance headphones. Good enough for normal use.
peder2tm
Thanks, I've read somewhere on Reddit that the output impedance is 7 Ohm so yes it might not be suitable for low impedance headphones, but I am surprised that it is not powerful enough. The specified output voltage is 16 dBu, which is 4.88 V RMS so it must be current limiting at lower impedances if it's not loud enough, or maybe the 7 Ohm output impedance is not correct.
JohnYang1997
China
It's single opamp 4556al . Voltage swing is pretty good but current output is not so great. Not bad but not great.
