CarlToft
I am looking to buy possibly a Xiaomi 12 Ultra when it launches. But I don't know which usb-c to aux dongle I should buy. I mostly use my Xenns (mangird) Tea and my YBF-ISS014, and I also mostly listen to flac files.
I didn't know what category to post this thread in.
I have been looking at the TempoTec Sonata series but I don't which model is the best, or if they are gonna launch a new one soon. I can't find any comparisons between eg Sonata HD pro and the new ones like MHD. If there are better options I would like to look at them too.
I live in Denmark so EU sites are welcome and my max budget is $80
All help is very appreciated.
DanielT
Sweden - Слава Україні
I keep my fingers crossed that you get tips and advice! I think it has been surprisingly little response that you received on your previous thread regarding this. Sharpening ASR forum participants, help Carl. :) There are many who have experience of exactly what Carl is interested in so ... tips and advice ..
C
CarlToft
Thanks a lot:)
Matias
São Paulo, Brazil
I have been looking at the TempoTec Sonata series but I don't which model is the best, or if they are gonna launch a new one soon. If there are better options I would like to look at them too.
If you can use 4.4 mm balanced pentagon cables, the the TempoTec Sonata E44 is an excellent option. The 3.5 mm Hidizs S9 Pro is great too but exceeds your budget.
A step below yet still great is the TempoTec Sonata HD Pro / Hidizs S8, 3.5 mm too. And if portability and small size is most important, then the tiny Meizu HiFi DAC is the best in class.
Haven't heard the TempoTec Sonata E35 or newer MHD yet. Or iBasso DC03 or DC04. But imo one cannot go wrong with any of these.
Matias
São Paulo, Brazil
You can get them all through AliExpress. Both TempoTec and Hidizs have their official stores over there.
C
CarlToft
I have heard that the sonata hd ii is better is it true?
Matias
São Paulo, Brazil
C
CarlToft
Don't know, haven't tested it yet.
Fair enough I am trying to find the article about it because maybe it is the opposite. I can ony find Sonata hd pro vs Sonata HD 1 not 2
litemotiv
$80 is perhaps a bit of an unpractical budget cap, since there is a fair group of good dongle DAC's just around the $100 mark.
I recently got a Hidizs S9 Pro that i'm very content with. When you order from their main website you can get a 10% discount when signing up to the newsletter. In total i paid €95 / $110 including shipping & taxes, and i received it in about 10 days (Western Europe).
C
CarlToft
Thank you but i heard that the Tempotec are the same but a little cheaper
litemotiv
That's possible! I chose the Hidizs S9 for the dual ports (2.5mm balanced / 3.5mm unbalanced) and the high output compared to the Tempotec:
If those factors are less important for your use case then the Sonata HD seems very good too in terms of the other measurements.
I'm using the Hidizs with a Xiaomi 9T Pro by the way.
C
CarlToft
My iems are pretty easy to drive so high output is not that important for me
