Vimberg Amea Bookshelf Measurements | SoundStage/NRC
MZKM
Land O’ Lakes, FL
https://www.soundstagenetwork.com/i...vimberg-amea-loudspeakers&catid=77&Itemid=153
0-15-30° H
45-60-75°H
At $14,000-$15,000 USD, I‘m a bit disappointed by the directivity mismatch around 2kHz. Without looking at the price, I would have called it a pretty good performer.
If you don’t know, Stereophile reviewed the Mino, the $31,000 ($39,500 with diamond tweeter upgrade) tower version, there is even another tower with larger woofers; the Mino’s measurements are pretty great:
https://www.stereophile.com/content/vimberg-mino-loudspeaker-measurements
Also, Vimberg is an “offshoot” of Tidal Audio. Stereophile reviewed their Akira model ($215,000) and the looks are near identical to the Mino and it’s larger brother and the measurements are similar (dare I say worse):
https://www.stereophile.com/content/tidal-audio-akira-loudspeaker-measurements
I feel sad for anyone who paid that extra ~$175,000 for the Akira.
I wonder how Tidal’s La Assoluta measures as it costs a whopping ~$600,000:
x9K-23EE0Dun5qBKakyJgFnR8ROsfENB_xyqRlhKzIxPQyjFottgcI8TkdeIyoag8Io_siXOv5qHI5vuhFbzinqyoO4q
They even have a whole spiel about measurements:
MarcT
East Texas
I heard the Mino at RMAF 2018, and I can attest that the sound was awesome, subjectively of course. Almost everybody there liked them a lot. Actually, the Mino is larger and goes deeper than the Tidal Piano, and for a lot less moolah.
DSC_0041 by MDTshots, on Flickr
DSC_0042 by MDTshots, on Flickr
Tidal Piano below:
DSC_0039 by MDTshots, on Flickr
Alexanderc
Florida, USA
Testing some speakers horizontal dispersion to only 45 degrees is a bit confusing and makes comparison difficult. Don’t Stereophile usually show results out to 75 or 90 degrees?
Edit: for example, Revel f228
M
MZKM
Land O’ Lakes, FL
Sometimes Atkinson simply can’t measure to 90° due to measuring setup/location restraints.
Beave
Yeah, I think some (many?) of the large towers are too big to put on a 'turntable' to rotate them.
thewas
What a nonsense text, I don't know of any loudspeaker claiming "20-100000Hz +- 2dB" but in the audio range where it can be very measured with not too expensive calibrated microphones.
tuga
Oxford, England
0-15-30° H
45-60-75°H
That tweeter is breaking bad way too close to the audio band...
M
MZKM
Land O’ Lakes, FL
True. However, the power of frequencies that high is low. So unless playing a vinyl and worrying about pops and such, I doubt it will be an audible concern. But would I like for the resonant frequency to be higher and/or have a reduction in the resonant peak, of course.
