DSJR
Don't forget - a few specialist pressings aside, vinyl is routinely cut with nothing below 40Hz and much below 150Hz or so turned into mono to save 'land' in the first case and also to prevent styli jumping in both cases. Cutting heads apparently overheat if you try to cut high level high frequencies so this rarely happens. I'm continually amazed vinyl sounds as good as it can and for some older decks and arms once liked, thank heavens for the likes of the beer budget AT VM95ML and SH...
