Volume Matching JND
Speedskater
Cleveland, Ohio USA
If a listener can say that one sounds better than the other, then the volume difference is more than JND.
With a JND, the listener can't identify why they sound different.
J
John Kenny
You mean at this JND threshold there is a fluctuating perception of difference/no difference?
I think what you're saying is that this is how the JND is established i.e where that threshold line is found by step testing ? So if they can't say there's a difference, it's below the JND & when the can statistically identify a difference it's above the JND
Blumlein 88
This isn't the usual definition of JND. Usually JND for loudness in this case is the minimum difference at which a listener will reliably hear one at a higher or lower level vs another signal. You can have a JND for frequency which would be the minimum ratio between two frequencies at which a listener will hear a higher or lower frequency.
The JND for hearing something as different (unspecified) appears to be lower than the JND for hearing a loudness difference. Which is why volume matching by ear makes two sources sound the same loudness, but they might still be heard as differing at smaller volume differences than the loudness JND.
Studying Weber's law might be helpful.
https://en.wikipedia.org/wiki/Weber–Fechner_law
And here is one bit of research showing a reasonably good correspondence with actually listening.
http://m.audres.org/cel/loud/NeelyAllen1998ISH.pdf
Weber's law would predict around .5 db to be JND for most sensations. You will see references to exploration of the near-miss with Weber's law. Equations can do a pretty good job predicting various sensation or perception based JND's at various levels, but usually is off by this near miss component.
J
John Kenny
Yes & for listening to music (which is mostly what is used in listening tests) it appears that anecdotal reports (I haven't seen any papers quoted) indicate 2-3dB is the JND
J
John Kenny
Here's research which throws the whole concept of volume matching using a 1KHz tone into question & the concept that we are less sensitive to amplitudes of LF & HF frequencies & more sensitive to mid frequencies
"Effects of relative and absolute frequency in the spectral weighting of loudness"
Which states that "The loudness of broadband sound is often modeled as a linear sum of specific loudness across frequency bands. In contrast, recent studies using molecular psychophysical methods suggest that low and high frequency components contribute more to the overall loudness than mid frequencies. In a series of experiments, the contribution of individual components to the overall loudness of a tone complex was assessed using the molecular psychophysical method as well as a loudness matching task."
"The stimuli were two spectrally overlapping ten-tone complexes with two equivalent rectangular bandwidth spacing between the tones, making it possible to separate effects of relative and absolute frequency."
"The lowest frequency components of the “low-frequency” and the “high-frequency” complexes were 208 and 808 Hz, respectively. Perceptual-weights data showed emphasis on lowest and highest frequencies of both the complexes, suggesting spectral-edge related effects.Loudness matching data in the same listeners confirmed the greater contribution of low and high frequency components to the overall loudness of the ten-tone complexes. Masked detection thresholds of the individual components within the tone complex were not correlated with perceptual weights. The results show that perceptual weights provide reliable behavioral correlates of relative contributions of the individual frequency components to overall loudness of broadband sounds."
Phelonious Ponk
So it seems there is a lot of reason to believe that level differences are perceived as quality differences, though at what level is arguable. Given such knowledge, why would one not simply level match as closely as your equipment will measure the difference? There is no reason to believe than unmatched levels will give a better result.
Tim
J
John Kenny
Tim
Yep & it would appear that there's no reason criticise or consider invalid listening tests which are not matched to within 0.1dB - 2 to 3dB seems appropriate
Blumlein 88
For loudness yes for difference no.
Phelonious Ponk
If what seems appropriate becomes well-established, I'd agree. In the meantime, I believe I would match as closely as my equipment will allow.
Tim
Phelonious Ponk
If this is accurate, it's even more dangerous to preference testing. If you can detect a difference but you can't tell it's loudness. It would be very natural to attribute it to something else.
Tim
J
John Kenny
Tim
Sure, no problem anybody matching as closely as equipment allows & it seems that 2-3dB is well-established reading the posts here - unless there are some DBTs that indicate otherwise.
Blumlein 88
I would ask what Tim is asking. Why not do the match and remove the issue? Even when using stepped volume in 1 dB steps you will be able to achieve .5 dB or less difference. Under what conditions is that not easy to do?
J
John Kenny
As I said I've no problem with that but then it seems that ABX tests are dismissed which haven't been matched to <0.5dB. Your posts here demonstrate you & AJ doing exactly this:
http://audiosciencereview.com/forum...hat-is-measurable-thread.214/page-6#post-6223
(quote=AJ Soundfield)Well, it should be obvious if the output voltages from the T&A weren't measured/precisely matched for A vs B....then there was no "test", never mind the stats.
(quote=Blumlein88)I concur with this. The ADC/DAC in use has switched relay level control. Other than the top two steps, it used 1db per step. It appears once setup they simply switched between inputs on the pre. They may have gotten lucky and the match was good. Most likely was a .5 dB mismatch. We don't know and with out good level matching this means nothing.
And you restate the same criteria later in the thread here
"If you can only change levels by 1 db, then you are almost surely looking at some mismatch in level. If you do the job properly that mismatch would not exceed .5 db. Call it reasonable doubt. Doubt which could have been assuaged by them explaining how they match levels and how closely they were matched. It also seems unnecessary for me to have to explain that to a DAC designer. Makes me think you are only interested in obstructing useful discussion by pest-like responses.​
DonH56
Monument, CO
The tests I helped perform agree with the above posts in that detecting a difference in loudness required a much larger change than simply detecting a difference. I obviously did not make that clear, perhaps obfuscating it by mentioning the time factor. Level matching for something like ABX testing, looking for a positive result as being any perceived difference, provides a different JND than changing the volume and asking if it got louder or softer. the latter relates to phons and things like the Fletcher-Munson curves, natch.
We did some testing using headphones to take the speakers and room out of the equation.
At that time (early 80's) much ado was being made about DBT and ABX testing and the need for precise (~0.1 dB) level matching. We were trying to see if we could prove or disprove that theory. There was much debate since ABX was fairly new and accepted theory and practice showed 1 dB was about the detectable limit for a change in loudness. Fast-switching DBT and ABX systems blew that out of the water, showed a clear preference for a system only slightly louder, and forced a rethink of what level matching meant. Most dealers had little in the way of test equipment back then and level matching by ear was common. As was savvy but unscrupulous salesmen turning the volume up a hair on the component with the biggest commission... It was the latter that actually drove my boss to look into the issue as he lost a big sale to that practice, at least so far as everyone could tell (and the salesman supposedly admitted it over drinks one night). My boss went on a quest to prove "our" products were better in a matched test.
Blumlein 88
Actually I don't see that this calls into question volume matching at 1 khz. For one thing it didn't extend the testing as high as 1 khz. Typically, unless gear has rather large response issues at either end, matching at 1 khz would result in the same relative level as matching at other frequencies. If you prefer 208 hz then use that. If the gear has response differences exceeding .25 db at either end those are audible and best possible matching won't change that audibility due to FR differences.
I repeat, yet again, once more, why harp on this? Match the levels and move on. You appear only to be angling to include sloppy testing matched with in 2-3 db which is sloppy beyond reason. 1 db is possible by ear, so matching worse than that is surely not much of an attempt at good testing. And yes, I did, do and will reject any test so sloppy as matched to those looser tolerances.
Further, I have been involved with and done testing matching levels by ear. It is more bother, and takes more time switching back and forth to do that than it takes to simply drop your multi-meter across the speaker leads and send a tone thru. So yet one more reason not to do it that way. It is more difficult, takes more time and is less accurate. If someone wishes to convince me of their carefully done listening results yet can't be bothered to own/use a multimeter, I won't lose sleep over dismissing those results. If you still find them worth consideration, repeat the test with matched levels if you wish to convince others.
J
John Kenny
I initially read it that way at first but on more careful reading, I realised what was being said here ""The lowest frequency components of the “low-frequency” and the “high-frequency” complexes were 208 and 808 Hz, respectively." - there were LF complexes in which the lowest frequency component was 208Hz & there were HF complexes in which the lowest frequency was 808Hz. So, no you can't say "it didn't extend the testing as high as 1 khz."
What you call "harping on", I call investigating - it's one of the areas I like about science - the investigative aspect
OK, thanks - the practicalities do come into it. I'm not favouring one side or the other, I just wanted to hear people's opinions & find any useful research which shone some light on the JND for volume matching
AJ Soundfield
Tampa FL
That appears to be a acoustics science journal, not an audiophile one. Are the results you're hanging your hat on, anecdotal in nature? Or where they obtained via controlled listening tests?
Not a member like you, so please clarify what methods they used, what were the quality checks, how they were proctored, etc, so that we know the results are rigorously science valid.
