- Joined
- Feb 24, 2021
- Messages
- 201
- Likes
- 114
I'm working with the following:
Spotify/FLAC listening:
PC USB>Grace SDAC BALANCED Balanced out>THX789 BALANCED OUT>AEON RT -- *789 set at Gain II about 12 o'clock for comfortable listening
Turntable Listening:
Technics SL-23 with AT 3600L RCA out> ART DJ PREII (LF cut/200PF gain set to peak transient red clip) RCA out>THX 789> AEON RT -- *789 vol set to Gain III 1 o'clock
My question is what's the best options to bring up the volume to the 789 from the turntable?
1)I was considering upgrading from the DJ PREII to the Zphono, but not sure this would up the volume to the 789. Seems in amir's review of the two, the Zphono had almost triple the output (at least if I am looking at things correctly!) (DJPREII 306 mVrms/ 36 db :: Zphono 1.1 Vrms/75 db)
2)I have an existing Yamaha MW12 mixer at my desk, which I could bring the PREII into, adjust the volume, then run the out to the 789 (note this would add the ability to output the turntable to my Mackie monitors as well).
3)Or is just compensating the volume with the 789 the best option?
Thanks in advance,
David
Thanks in advance,
David
