- Thread Starter
- #41
Twisting the wire is probably sufficient (notably for short runs).
Fuse sizing is discussed earlier. My thinking is to size based on how hard you will push your amp. If it will see light duty use, a 3A fuse may be fine. If you expect to drive harder or drive multiple modules, would size closer to the power supply fuse's value (for Hypex A400 would be 12A). There are more experienced folks on ASR that may have more specific advice. A very specific sizing requires specifically measuring the amp and I do not have any Purifi amps on hand.
