BrokenEnglishGuy
- Joined
- Jul 19, 2020
- Messages
- 1,941
- Likes
- 1,163
i upgrade my bookshelf in my smalish room to a mid size floorstander... i couldn't be more happy. im using a bit of room correction and the '' O '' foam in both bass ports.
But there are few thing that i notice, first the floorstander seems to have unlimited spl or something like that, much higher than my r300, i have the R7.
But more than the bass extension, the weight in the sound is much more fun and correct, that's only because the floorstander have 2 woofers instead of one? or also have more area in 100hz-400hz helps to the weight in the sounds? for example, the drums sounds much better...
At lower volume i feel the same, i can use the floostander at low volume and still get fun out of them, and if i push just a little bit the towers start to move and the walls and my chest know that, if i push a little bit more the towers show me a live concert or something like that xD
These towers can move a lot of air, also i find at similar SPL the woofers in the floostander move less or that is my impression, but the weight and the bass feel much better...
So, whats was the deal? the larger cabinet make the speakers sounds much better or add another driver to the speaker was the magic? or both
I'm a bit confused
I'm a bit confused
