Weird Denon DRA-800H and JBL Stage A190 measurements
Nonick
This might be a better fit for Speaker subforum, but it can fit in here.
After a long and nasty SMSL AO200 story, i've acquired JBL Stage A190 speakers and (... drumroll..) Denon DRA-800H (brand new).
Decided to measure speaker response with UMIK-1 and REW.
So here's the first set of measurements:
PC > output HDMI > Denon DRA-800H (Stereo mode)
Combined left+right response
Left speaker response
Right speaker response
Very strange dip on left speaker on 130 Hz. Performed multiple measurements, but the dip remains. Might be room acoustics, but the speakers were placed and measured in the same position. Performed new, though primitive, measurements. I switched Denon to Pure Direct mode.
On first set of measurement it was in Stereo mode.
New measurements with Pure Direct enabled - no dip at 130 Hz!
1) Overall measurement, distance 50 cm, on axis, Pure Direct
2) woofer, mid woofer, tweeter separate mesurements, Pure Direct. Visible crossover at cca 1.8 KHz.
3) Switched to Stereo mode - no smoothing
4) Pure direct - no smoothing
The room is bad for acoustics, no damping, speakers close to wall, so its not an ideal measurement chamber.
What concerned me before the measuring was speaker response. Listening test was performed before measurement and JBL Stage A190 was a love at first "sight".
In general,with primitive measurement methods, results are not that bad.
But the Stereo/Pure direct mode on Denon DRA-800H has serious dip problems.
Denon's transformer is buzzing as crazy (6 days old unit).
Denon DRA800H buzzing transformer noise
This might be a faulty unit or the clue for stereo/pure direct performance problems :)
P.S. this one is with PCM5102 DAC.
raindance
Seems a little OCD - you won't hear the dip as it is so narrow. I highly doubt there is a fault with the amp, in all likelihood it is the SBIR frequency caused by the distance of the speaker from the wall.
N
Nonick
Left channel always with 130 Hz dip in stereo mode. In pure direct - theres no dip. Though it might be the buzzing of transformer that annoys me to the core ;)
MacCali
no one has the stock measurements of these speakers huh? trying to do some EQ. EQing off of those measurements isn't going to work right? since my room is different from yours. Not sure if it will do anything, I know some speakers cannot be EQ'd.
It's a touch bright, but my chain is on the warm side of things so I am sure that's bringing down the brilliance
*Also was expecting a touch more bass in general, but only bass heavy songs is where it shines.
