What’s Your Triangle in Stereo Speaker Listening?
Which triangle is your stereo speaker setup?
benanders
Hong Kong SAR
What triangle best describes your stereo speaker setup relative to main listening position (MLP)?
Caution: some Isosceles look like Equilaterals, without actual measurements! o_O
Please consider a post with setup details.
Useful ingredients include:
(1) Triangle leg measurements (metric or imperial, pref to nearest cm / inch) appreciated.
(2) Speaker make / model ( = easy for readers to look up manufacturer specs) appreciated.
Photo(s) with the above typed details welcomed!
Multiple systems okay to enter.
Past systems okay to enter IF you recorded above ingredients
Fake entries :mad:‘ed upon.
Car audio, headphones and assorted mono creatures (e.g. HomePod / JBL Charge / solo Devialet) inapplicable.
Let’s keep it constructive!
napfkuchen
Germany
Isosceles (between-speakers leg longer) with Genelec 8331
between speakers: 2m
speaker-ear-distance: 1,30m to 1,60m
Wider stereo panorama is my preference.
Joffy1780
Isosceles - between speakers shortest. Speakers are Kef Q750 (stereo and multi-channel setup)
Between speakers dist of 2.1m and 4.3m speaker to ear.
Not ideal, but quite constrained by the room.
DavidMcRoy
Equilateral, 2m on all sides (Doesn't matter what speakers I'm using that day)
These are Acoustat SPECTRA 1100s. "Objects in photo are much closer than they appear." The wide angle lens is very deceptive.
Elkerton
9' all round has offered the most spaciousness while retaining imaging in my main system in the recreation room. (Isosceles in the living room to achieve WAF :))
Gary_G
SW Virginia, USA
Isosceles, 5 ft between speakers, 6.5 feet from each speaker to listening area. But I started measuring the room (15ftx15ftx9') with REW and found that
sitting farther away and somewhat Scalene(12 from left speaker, 11 feet from right speaker and still 5 ft between them) gives a better response. I have the speakers toed in so I want to set them parallel with the room and remeasure.
fpitas
Northern Virginia, USA
Maybe 11 feet between speakers, my chair is about 10 feet out.
gnarly
Just voted for multichannel. Although my setup is really for stereo, enhanced with a center speaker via LCR matrixing.
Left......9ft.......Center.......9ft ........ Right
............................14ft
........................listening
So speakers' arc 18ft wide, is long isosceles leg.
Joffy1780
Downstairs system. Stereo with sub.
Isosceles - between speakers leg shortest.
Between speakers - 1.71m
Speakers to ear - 1.77m
Speakers - Kef q4
Pretty close to equilateral, but not quite.
Again, pretty constrained by room + waf.
Joffy1780
More toward equilateral and off wall.
Yeah, that would likely be better. The good thing about the q4s is they're front ported and don't sound overly boomy near walls.
Plus my 6 year old uses this system a lot to practice her dance moves and I'm worried she'll knock one over, or put a flailing elbow into a tweeter if I bring them out any :p
Somafunk
Scotland
Equilateral for myself, I sit just inside the triangle
Joffy1780
Isosceles speakers leg longer? Measurements or it's not equilateral :p
@benanders what is the leeway, btw? Within a mm, a cm, or say within 5 cm?
theREALdotnet
I’m rather partial to the trapezoid setup, spanned by two speakers and two ears. :)
theREALdotnet
I’m equilateral, ~1.8m. I guess you could call that nearly near field. With speakers pointing straight forward this gives me great 3-dimensional imaging. Visitors to my listening room usually suspect hidden speakers in the absorber panels on the sides.
