mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,455
- Likes
- 24,872
Keeping them wasn't really an option -- as I bought them expressly for another hifi fellow traveler.You should have kept them.
I would have recommended you try some Russian 5881's in them.
Though most deficiency in the sound was probably due to a cheap output transformer.
The OPT was indeed kind of nominal -- but not as nominal as the one used in the original Realist morph.
You cannot see it in the catalog scan because it's mounted under-deck.
Indeed, with the below-decks OPT and octal voltage amps and splitter --
Check that: The "Realistics" look like a bona fide Grommes "LJ" clone -- although the OPT is indeed not as beefy as the LJs.
(borrowed Internet photo; not mine)
A little Arkay amp/carcass that passed through some years back.
