What electronic audio products you want tested most
What electronics audio product you like to see tested more
  • Power and Integrated Amplifiers
    Votes: 634 55.2%
  • Headphone Amplifiers
    Votes: 182 15.8%
  • Home Theater AVRs
    Votes: 307 26.7%
  • Home Theater Processors
    Votes: 199 17.3%
  • DACs
    Votes: 350 30.5%
  • Streamers
    Votes: 262 22.8%
  • Combo DAC and Headphone Amplifiers
    Votes: 237 20.6%
  • Phono preamp
    Votes: 106 9.2%
  • DSP (digital signal processors)
    Votes: 379 33.0%
  • Vintage audio products
    Votes: 270 23.5%
Head_Unit
I am interested in power amplifiers into real loads (not power resistors).
I am pretty sure all low power electronics are near to my definition of transparent for music already, even the not very good ones...
YES! But it's hard, you need some ginormous passive components. That's one reason the Power Cube https://www.audiograph.se is expensive. I was going to set up a 70 Hz capacitive and inductive load setup, maybe 45° phase angle. However that reviewing gig died and I changed what I was doing anyway so it never happened. I chose 70 Hz as not having common low harmonics with 60 Hz American mains frequencies.
Joachim
I would like to see more reviews of pro audio gear that is also of interest to non professional users.
Active studio monitors and subs, AD/DA converters, Room correction systems (hardware and software) and acoustic treatments (absorbers/diffusers/traps).
Trdat
Yerevan "Sydney Born"
We need to compare the distortion characteristics of an active crossover to a passive crossover in a speaker.
This would be a first or at least ground breaking in understanding how they compare.
Personally I think this is vital to know as these types of crossovers will still be used for a while. I've moved onto digital crossovers/DSP but still have a few speakers with passive and active crossovers and would love to know what my better option is between the two.
audio2design
Using feedback and feed forward techniques using DSP you are guaranteed to be able to achieve lower distortion if done properly in an active speaker design. But that's not the same as simple active / DSP crossover.
Trdat
I should have said electronic crossover. Yes, I agree DSP crossovers will definitely give you lower distortion. But what about say a passive internal crossover of a speaker vs a Marchand XM66 crossover with the same speaker?
DimitryZ
Waltham, MA, USA
Since DDCs or reclockers are again entering the marketplace, I would like to see them put to the test.
Plcamp
Ottawa
I saw a couple of folks like the xkitz opamp based crossovers, and I believe they were tested to be very low distortion, but then a gent on diyaudio fb said it’s output can’t reach 2v on the negative rails. I believe he actually created a new PCB to solve that.
I would certainly like to see an opamp based crossover tested.
But the flexibility of dsp is hard to beat, and therefore will dominate the future?
Robbo99999
ocrazor
USA
I'd like to see the HT Omega Claro Halo or eClaro sound cards reviewed, to see how these historically top-of-line sound cards compare to newer options.
D!sco
Dayton Audio produces a very cheap line of DSP Amplifier boards. I'd be fascinated to know how far these units could be pushed. They're advertised for boomboxes and car audio use, but if they fit into hifi applications, it would be a welcome drop in the cost of active speaker development.
https://www.parts-express.com/Dayton-Audio-DSPB-ICP1-In-Circuit-Programmer-USB-325-132
https://www.parts-express.com/Dayto...D-Mono-Audio-Amplifier-Board-with-DSP-325-135
https://www.parts-express.com/Dayto...lass-D-Audio-Amplifier-Board-with-DSP-325-126
https://www.parts-express.com/Dayto...B-KE-Kernel-DSP-Expansion-2-In-3-Out-325-1300
https://www.parts-express.com/Dayto...on-Cables-for-KAB-and-DSPB-Connection-325-129
redshift
DSP’s that’s used by pro audio engineers and streamers with integrated amps and competent DSP’s for adding effects (per song) and not just room “correction”.
IMO.
mslim
DACslut
Could you do some kind of comparative "Shootout" reviews? That would be kinda cool.
gvh1234
Southampton, UK
From a purely academic point of view - the Logitech Squeezebox Touch. Still plenty of them out there. Just how good is it?
Yes, I know it needs a server, but it's a classic and I feel it deserves a moment in the spotlight.
ripmixburn
Toronto, Canada
Capital idea. This incredible theme created by a contributor has breathed new life into my Squeezebox setup. It's a joy to use. https://github.com/CDrummond/lms-material
somebodyelse
Looks like it could hold its own in comparison with a lot of the current crop of streamers.
https://archimago.blogspot.com/2013/02/measurements-logitech-squeezebox-touch.html
https://archimago.blogspot.com/2013/02/measurements-logitech-touch-as-transport.html
