What is 'incompetent digital' ?
Opus111
Opus111
Zhejiang
I agree there Amir, there's no battle of words. But there is so far an absence of curiosity about whether these measurements have any significance in the real world. So if anyone curious has questions by all means chip in and ask, don't be deterred by the high level of banter.
AJ Soundfield
Tampa FL
We're very curious, let's hear about the audio significance of what you posited about rising IM with the MiniDSP.
Of course, if you don't actually know...
Blumlein 88
Demonstrate your curiosity and you might receive a response. Until then, no cigar:D
Opus, if someone wishes to read, take part in or contribute to this thread, your endless ridiculous total content free replies don't help at all. If this is all you have to contribute you should feel incompetently informed to post.
Blumlein 88
How hard would it be to run a bypass test if one believes this is audible?
Source>>minidsp & direct to pre/amp inputs 1 & 2. Check voltage output between switching. Match.
See if "grass" is audible. Or just smoke related.
Bingo. That is all that is needed. Isn't it funny how ear trusting audiophiles seem to veer away from using their ears to determine such stuff? They argue, imagine, and pontificate yet don't want to simply listen and see if they hear a difference without knowing how they expect the answer to turn out first.
Blumlein 88
If one has a hypothesis, the scientific method tells us it first needs to be a falsifiable one, then if so we then proceed to test it. Looks like your hypothesis here is 'Opus has nothing more to contribute other than banter with AJ'. Are you going to test that hypothesis?
My opinion is that Opus 111 is a rhetorical a-hole. My opinion is Opus 111 can falsify that anytime he wishes. My opinion is Opus 111 can't help himself and will not falsify my opinion.
I am sure Amir wishes people not attack posters, attack their arguments. In this case, there is no argument to address which is my whole complaint.
Ethan Winer
Industry Insider
New Milford, CT, USA
Such a criteria would establish nothing beyond which DAC suits one person's personal preference, and then under a very specific set of recording and playback chain circumstances. How, exactly would you propose to determine this subjective lack of audible coloration?
Others already replied before I got to this, but I'll add just bit for clarity:
Yes, it's difficult / impossible to separate out a D/A alone to assess if it's audibly transparent and has no sound of its own. So instead we use both the A/D and D/A in the same unit. If passing a signal through A/D then D/A comes out indistinguishable from the source in a proper (level-matched and blind) test, both the A/D and the D/A are known to be transparent. And then we can use that device's A/D to assess other products that provide only the D/A portion.
I'll add that these days transparent converters are common and affordable. For me this is about being a smart consumer: Why spend $1,000 or more for an outboard D/A when a $50 converter (or the converter you already have in your Blu-ray player or laptop) is transparent?
--Ethan
Don Hills
Wellington, New Zealand
O ... If passing a signal through A/D then D/A comes out indistinguishable from the source in a proper (level-matched and blind) test, both the A/D and the D/A are known to be transparent. And then we can use that device's A/D to assess other products that provide only the D/A portion. ...
Not quite. All we know is that the specific combination of A/D - D/A is audibly transparent. We don't know if any shortcomings of one - say, a less than optimum filter implementation - are being masked / compensated by the implementation of the other. Testing with different combinations of devices is necessary to gain confidence in the transparency.
(For what it's worth, my personal opinion is that most devices built with attention to competency (as opposed to aiming for the lowest cost) are "close enough for rock'n'roll".)
Sal1950
The Chicago Crusher
Central Fl
--Ethan
Very good to hear from you Ethan, You valuable input is always much appreciated by us here at ASR.
il saluto
Sal
Fitzcaraldo215
Call me a purist or any other name in the book, but I absolutely do not want any extra d-a, a-d, d-a conversions in my system. They cannot possibly benefit the sound. At best, they are neutral, but I do not want to waste my time determining whether they are or are not. It is all to easy to just avoid them entirely. One final d-a will do for me, thank you.
Blumlein 88
I don't think anyone is suggesting unnecessary ad/da conversions. But if one or more are audibly benign it lends credence to the idea a well done single da step is audibly benign. So at that point there is nothing to be gained from exotic expensive DACs trying to guild the lily or fix an imagined problem that isn't.
TBone
... too dismissive of this "smart consumers" expectations.
IIRC, my current BRP cost about ~$200; is 24/192 capable, and more importantly it has analog rca-outputs allowing it to be plugged directly into my main stereo system. I would not label it incompetent by any means, it may not have Oppo's build quality, and it certainly doesn't have the sonic chops to replace ANY decent CD player or transport/dac I've ever used, even @192, but for my personal HT setup, it serves my expectations well. Along with that BRP, I have 3 other CD players at present ... yet, only one isn't overly opaque (imparting its own sonic character on every CD played).
I'm here to understand why that is so, until then ...
AJ Soundfield
Tampa FL
I'm here to understand why that is so...
Your method of comparison lacks any controls and is thus error prone.
TBone
I can live with being "error prone", being fully accountable for any such "errors" I may incur within any decision making process ...
AJ Soundfield
Tampa FL
Great, well there's your reasonable explanation for all those disc player "sounds"
Blumlein 88
I am assuming Tbone you get what AJ is pointing to though somewhat obscurely. That if your impressions are under sighted conditions with uncontrolled listening the differences you hear might disappear with level matched listening especially level matched unsighted listening. The assumption being all your CD players are in good working order with flat FR, low distortion and noise levels as is the norm. So have you done some A-B comparisons while at least matching the sound levels?
TBone
88, they all work fine, although I replaced one's power-supply capacitors just recently. Once that unit has some playing time under its belt (just to avoid a potential variable), perhaps I'll rip each from analog output to digital recorder, and measure them accordingly for comparison. (I'd also like to measure my old Rega Planet, which I still have limited access, very interested in how that player may measure). And yes, I've been involved in a number of "controlled" tests, some sighted, others not; that said, I rarely attend those sessions anymore ...
Cosmik
I admire AJ's tenacity. But more fruitful than demanding listening tests would be to just look at the design and the measurements. If they are equivalent, the listening test is a waste of time. The listening test will never happen, anyway, which leaves the issue hanging, unsolved.
I don't understand the fascination with (non-existent) listening tests. If it were only a case of audibility in listening tests, we would probably still be using 14 bit non-oversampled DACs. However, as technology advances, a much better DAC costs no more to manufacture. Even if we can't hear the difference directly, we should choose the better design, anyway. If it allows more leeway in headroom when recording, or with DSP room correction etc. it is still worth having.
